Sonoff S31POW polling interval
I am wanting to work with the power readings thrown off by the S31POW.  I notice that polyglot seems to retrieve these readings using some sort of polling. They only update every three minutes (per the log).  Not very helpful when you have an application needing more frequent readings.
The Sonoff itself updates immediately, it's just that Polyglot does not get the updates promptly.
Is there a setting somewhere that this can be changed?
Solved by TriLife
Hello Max,
Tasmota, by default, sends an update every 300s... You can change this by adjusting 'teleperiod' in the Webui console. As I recall the minimum is 10secs... The MQTT plug-in should report, if there was a change.
Edited by TriLife
Added info
Ah, yes, "TelePeriod 20" does in fact set this to 20 seconds.  Nice to be able to set this on a per-device basis!  Thank you!
