Weird Device Adding after V6
I added new devices for the first time in a long time so not sure if this started now or earlier. Also not seeing other reports it's probably a me thing.
First when I first log in, the 'New Insteon Devices' window always shows up for whatever the last device I added was. In my case a 2842-222 motion detector. I can close it, but comes right back next time I load the UI.
Similarly, devices appear to have shown up 3 times in the UI. It's the same address as the New Insteon Devices shows up every time and I already unlinked it once and relinked. Next time in the admin UI 3 copies and the new devices window.
Second, Similar behavior with ZWave
The next device I added, I started by excluding one of my Somfy shades that uses the zwave bridge. It was acting weird, said it couldn't connect, so I removed it and added it back. Now every time I connect to the UI the Z-Wave Device Discovery window is always there and clicking cancel doesn't make it go away it's stuck.
Similarly, when I added it even if I say 'Group Devices' I now have 3 entries, but only for a subnode 'Binary Switch'. I can do 'group devices' on one of the binary switches and it added it to the shade's main node, but the other two stay.
Any thoughts why this would be? It's really cluttered, and having all the windows that never used to be there. I"m worried my install is corrupted.
Solved by hart2hart
I reported to UD and response was it’s a known issue and will be fixed in the next release. If you reboot eISY, the extra devices go away.
