  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Schlage with Schlage App, Apple Home, and NodeServer
@Goose66 and others. I'd like to use my locks so that I can unlock with Apple Watch after a run. When I first got the I could only use one of these methods at a time. The nodeserver is great and so I can now do things from Schlage App and eISY NS. I want to add Apple home for watch and iPhone access. I located the following Schlage Encode Plus in Apple Home (w/ HomeKey) and Home Assistant - Hardware - Home Assistant Community
Does anyone have experience with this config to support all three? The article mentions Home Assistant but it feels like the NS does the same.
Alos, I see mention that using locks via Thread makes battery life 2x to 3x longer. Is it possible to leverage it with the NS or some other decent path like through HA?
Edited by hart2hart
22 minutes ago, Goose66 said:
If you can access the locks via Matter/thread , you shouldn’t need the plugin (node server).
I'm using only Wifi as far as I know and want to have control in eISY eco system like now and to be able to use Home Keys from Apple Watch and iPhone.
Edited by hart2hart
@Goose66 , I contacted Schlage support and received updated instructions compared to when I first purchased the locks. The locks now work all three ways:
1. Schlage App
2. HomeKit app
3. Nodeserver
The new instructions is to add to Schlage App first and then in the Schlage App to take option "Works With Home?" to add them to the Apple Home app. I can now unlock with just touch of iPhone and Apple Watch.
