December 20, 2025Dec 20 >Except for one time, when everything run perfectly. I did nothing but it worked. Sadly it has only ran once . any ideas ?
December 20, 2025Dec 20 It's possible that the contacts on the SD card oxidized. Remove power from the ISY, remove the SD Card and clean its contacts with a soft eraser.
December 21, 2025Dec 21 You may also want to try another wall wart power supply. They have a failure rate after being in service for awhile. Over the years I have had a few go bad.
