Can't run isy994 anymore, except once
>Except for one time, when everything run perfectly. I did nothing but it worked. Sadly it has only ran once . any ideas ?
It's possible that the contacts on the SD card oxidized.
Remove power from the ISY, remove the SD Card and clean its contacts with a soft eraser.
You may also want to try another wall wart power supply. They have a failure rate after being in service for awhile. Over the years I have had a few go bad.
