Sonos NS stopped functioning
About a week ago, the node server stopped working. usually a simple restart sets it straight--but not this time. Today I tried re-installing it all together but no luck. Whats strange is that in the AC, it appears to be registering volume and volume changes correctly and instantaneously. But I cannot send commands to sonos from the AC at all.
Log attached. Any help is appreciated.
ST-Sonos_1-3-2026_24015_PM.zip
I'm not sure. I don't have any Sonos devices so I can't do any debug/testing other than analyzing your log files. Doing that I don't see anything that looks wrong.
At 12:20:45, it looks like you tried to send the PLAY command for the speaker identified by 7ad3b3a. This is from the PG3 log. After the command is sent to the plug-in, there's a message to IoX requesting that it set 7ad3b3a's status for the ST value to 1.
In the plug-in log, there's an error "NS: undefined". This error is coming from the interface between plugins and PG3. I've seen this a lot from ST-Sonos and it seems harmless. But since I can't run the plug-in, I can't debug where in the interface layer it's happening.
The plug-in code for the PLAY command is pretty simple:
call the API's play command for the device
set the ST value to 1
The plug-in uses a third party library, JishiAPI, to communicate with the Sonos devices.
From the logs:
  • IoX sends the command to the plug-in
  • The plug-in sends the command to the JishiAPI
  • The plug-in updates the status
Which is indicates that the plug-in is doing what it is supposed to do.
Now the JishiAPI communicates with the Sonos devices by sending http requests to a server component called node-sonos-http-api/server.js. This component is supposed to be installed when you install the plug-in and started when you start the plug-in. If it is not running, the plug-in would not be able to do any communication with the Sonos devices. You indicate IoX is getting updates from the device which implies this component is started and working.
From the logs:
Thanks for the reply. I appreciate you looking into it. Unfortunately, I'm no closer to resolution though. @simplextech any assistance would be greatly appreciated.
@simplextech handed the plug-in off to me, he is no longer working on or supporting the plug-ins he wrote. I attempt to maintain them now.
Like I said, from the log, it looks like the plug-in is working correctly so the problem likely lies outside the plug-in's control.
It could be that the JishiAPI server is not running. That seems unlikely if you're getting updates from the speakers. You can check that it's running using a browser and going to http://<polisy/eisy IP address>:5005 This will bring up a Sonos API page with information about the JishiAPI. Including information on how you can send commands from the browser. If this doesn't come up in the browser then the server isn't running and we can try and debug the reason for that.
It could be that the JishiAPI server isn't able to communicate with the speakers. You can test this by using the instructions above and attempt to send commands via the browser to the speaker. If that's failing, the error may give us some information as to why.
The process of sending commands via the plug-in is pretty simple
  1. IoX sends a command to the plug-in. This typically has the node(address), command, and possibly a value.
  2. The interface layer looks at the node address in the command and forwards it to the that node.
  3. The plug-in parses the command and value out of the message sent and executes the command
    1. For the PLAY command, it uses the JishiAPI to send the proper http request to the Jishi server
    2. Sends a status update back to IoX
In your log, I see all of those steps happening and no errors being reported for any of them.
19 hours ago, bpwwer said:
sending command
OK. I confirmed that the JishiAPI is running AND I can send commands via my browser to sonos and it works.
I just published a new version of the plug-in to the store. It adds a debug message that shows what request the plug-in is making to JishiAPI server and provides an improved error message should that request fail.
The new version is 1.0.12
Noticed a couple things. The NS actually does work on some of my players still. Overtime, I have changed the name of some players in SONOS and moved them around the house etc. In the AC, the player names never update though. I wonder if this has caused the issues. New log attached. I attempted to send text-to-speech to several zones from the AC. It worked on some but not on others.
Question:
Since using "Discover" does not seem to update my sones node names
Can I delete a single sonos zone in the NS Nodes tab? And then try discover to add it back?
If not, can I fully delete the NS and then re-install?
ST-Sonos_1-14-2026_121451_PM.zip
Looks like the requests being submitted to the Jishi server are failing. The error is the same as what I get when I send a request for a speaker that doesn't exist.
I believe that changing the names is what's causing the issue.
When the plug-in creates a node for a speaker, the key identifier for the node is the node address. The node address is derived from I believe the speakers uid.
When the plug-in start or you initiate discovery, the plug-in compares the address to determine the node was previously found and created. It doesn't really care of the name changed. This is by design as in most cases, the address and name remain linked and a constant.
The Jishi server, on the other hand, uses the speaker name to identify the speaker. So when the plug-in sends to the commands to the Jishi server, it's sending them using the old name, which no longer exists, thus causing the error.
This has been addressed in the plug-in interface where the plug-in author can force the node name change on discovery. I can look into doing this as I believe it would be the right way to handle it for Sonos speakers. However, ST-Sonos uses a different language than most plug-ins and I'm not sure the force rename feature is available to that language.
Deleting the nodes and letting the plug-in re-create them should also solve this issue. You'll probably have to delete them both with PG3 and with the Admin Console. If you look at the node listing in PG3, each node has a "Delete" column with an "X" button in that column. Clicking that will delete the node from the PG3 database. In the Admin Console you can right click on the node and one of the options is to delete it. Once it's deleted from both places, restart ST-Sonos and it should re-create the nodes with the correct names.
