15 hours ago15 hr Long time user with lots of Insteon equipment and what I thought was pretty reasonable knowledge of the Insteon protocol and isy software but I'm running into some issues so thought I'd come back to the forums and see if anyone has some thoughts. I've moved mostly to home assistant but still love the eisy for insteon management and use it primarily for that so don't spend as much time in the interface as I used to.I feel like I may be running into some bugs in the eisy and would like to get a sense if other people are having these issues or it's just me.I had a power outage and it seemed to have fried my PLM (eisy is on UPS and stayed up), I replaced it with a spare and used the eisy to do the swap. Most of my house seemed to get updated fine with the new PLM address but for some reason most KPLs didn't and I've been having to factory reset them and restore them.This brings me to my first odd issue, some of my KPLs have had their database record in the eisy zeroed out. Logs complain about not being able to read the file and if I look in /var/isy/FILES/CONF/ on the eisy I see the file (XXXXXX.REC) there but of zero size. This happened once before and I removed those devices and readded them to fix it. This time it was three different KPLs. Both times it only happened to KPLs.My next odd issue is these are all 6 button KPLs tied to fanlincs, so the 4 middle buttons have mutually exclusive buttons for fan speed. I've done it the exact same way with a scene for each speed for 15+ years. When I readd these KPLs and set them up from scratch the buttons don't work correctly anymore. When you hit Fan Low instead of that light coming on the other three do. Fan High turns them all on. I've double checked my scenes and they look the same as other ones that are working. I'm wondering if some how the eisy isn't setting up the insteon scenes properly any more.Lastly, everything is soooo sloooow and it didn't used to be that way on the old 994i. Things should be so much faster on the new hardware. I don't even know what it's doing I just stare at the "System Busy" progress bar which very slowly goes to 100% then happily starts over again and again. I pull up the event viewer and there is nothing going over the wire. I look at the OS and it's using barely any CPU. I had to do a switch swap and it took over 30 minutes.Anyway I'd love any thoughts or suggestions on how to stop the database from becoming corrupt or fixing my KPL scenes. Edited 15 hours ago15 hr by apnar
11 hours ago11 hr When you swapped out the PLM did you follow the atached procedure ? Replace PLM Procedure (EISY or POLISY).pdf
11 hours ago11 hr Author 20 minutes ago, Techman said:When you swapped out the PLM did you follow the atached procedure ?Replace PLM Procedure (EISY or POLISY).pdfYes. I deleted and redid my fan button scenes and they seem to be behaving now so that may have just been a fluke.
