Embrighten Smart fan -- ISY Portal ?
I just installed the last of 4 Embrighten smart fan Zwave controllers. They look like on/off switches. Hitting the "up" once causes the fan to come on and hitting the "down" once causes the fan to go off. To increase the speed, you push the up for a while until you hear the speed increase.
These have the following entries: Dimmer switch; scene button 1; scene button 2; SC basic asssoc 2; and SC basic assoc 3.
I have been renaming the "dimmer switch" part from "ZY 025 dimmer switch" to "Bedroom fan" (or whatever) and using that to work with ISY portal. That SEEMs to work, in that I can use an echo to turn this on/off, and also select low or high speeds (I remember there's no "middle", so you have to say 50% power).
Is there a better way to do this?
Also, I end up with extra elements. Should I also name with with the "Bedroom Fan" or just leave them?
