May 23May 23 I'm struggling how to figure out i3 Programming. Here is what I'm trying to accomplish. I have an i3 Keypad that acts as a dimmer for some recessed lights with the load being on button #1. I want the 4 buttons on the keypad to control 4 scenes (Bright, Soft, Night, Off). For Bright, Soft and Night, I want to have the recessed lights at varying dim levels AND (the part that I can't seem to get to work) I only want the LED for button 2 on for Soft and Button 3 on for night (i.e. button #1 LED should be off even when the load is on). I can't seem to have the load on and the LED off without having all 4 LEDs off. Amy I missing something?Ron
May 23May 23 6 hours ago, RPruitt said:Amy I missing something?No. I don't believe that the load can be "on" and the backlight to be off.
June 20Jun 20 I have several of those i3 keypads and went through multiple attempts at doing something logical. Similar I have scenes called bright, normal, cozy and off. In the end, I decided that trying to keep the keypad in sync with which scene was active would never work in a way that would make me happy. So I started over and decided to make the buttons momentary on. Which means when you press the button it sends and on, But then inside the scene, I turn that button off. So it turns on, sets the scene and then turns off. This means I end up with essentially no buttons on except during the moment I am setting the scene, except the load button will always reflect that load if it is controlled by that keypad, so I normally just use the top button to turn that individual light on and off.I know this isn't quite what you asked but maybe spark some idea. Edited June 20Jun 20 by Andy P
