June 8Jun 8 Hi All. ANYONE out there with a Zooz ZSE70 able to view and use the Temperature data it is supposed to send? None of my nodes for it show Temperature but it is one of the main advertised features of this sensor and one that I want to use. ANY feedback appreciated. I am currently on v5.8.4 on a Polisy but have an eISY for spare that I will eventually move to - I will move to it sooner if someone tells me that it will enable seeing & using Temperature from this sensor. Thanks!Shawn
June 8Jun 8 I have an EISY with 6.0.5 firmware and the ZSE70 shows the temperature. You should probably try updating your Polisy/Eisy firmware
June 9Jun 9 Author 3 hours ago, Techman said:I have an EISY with 6.0.5 firmware and the ZSE70 shows the temperature.You should probably try updating your Polisy/EisyDo you remember when you installed your ZSE70? Or, do you remember what level you were at when you installed it?Thank you, but correct me if I'm wrong - the next version after mine (5.8.4) had a good chance of bricking your Polisy, right? (no prob for eSIY) Also, I thought not long after that they stopped Polisy from getting new versions before the v6.0.0 arrived?Thanks!
June 9Jun 9 It's best to open a support ticket before you try to upgrade your Polisy . See the link belowUpdated Software Available! - Current Release Announcements - Universal Devices ForumYou'll want to have the lastest firmware versions on your Polisy and EISY before you migrate from the Polisy to the EISYDo you have the UDI Zwave/Matter board on both the Polisy and Te EISY?
June 13Jun 13 Author On 6/9/2026 at 9:52 AM, Techman said:It's best to open a support ticket before you try to upgrade your Polisy . See the link belowUpdated Software Available! - Current Release Announcements - Universal Devices ForumYou'll want to have the lastest firmware versions on your Polisy and EISY before you migrate from the Polisy to the EISYDo you have the UDI Zwave/Matter board on both the Polisy and Te EISY?Yes, I have a new ZMatter-USB to replace the ZMatter-Internal in my Polisy. My eISY has not been out of the box yet so will have at least 1-year old+ firmware. That's a bit of a kenundrum - how do I migrate if I can't safely update the Polisy. But that is smart, I will open a ticket for that. Thanks for that recommendation. I take it you are unable to answer my other 2 questions about your ZSE70 installs?
Saturday at 02:27 PM5 days @ShawnW I think the ZSE70 was installed when I was either on 6.0.4 or 6.0.5. It works flawlessly on 6.0.5
Saturday at 03:38 PM5 days I also have a ZSE70 installed on eisy 6.0.5 with the ZMatter board and it shows temperature
