HomeKitHub Production Release
This is the first production release of the HomeKitHub Professional edition. The Standard edition has been available for a few weeks which allowed pairing of a HomeKit compatible device to the plugin and control of that device was handled by another plugin. This was done to bring the Ecobee Plugin back to life for those previously using the Ecobee Cloud method which Ecobee took away from us.
The Professional Edition allows creating and controlling those HomeKit devices directly in this Plugin. The initial goal was to get a Honeywell T10 thermostat pulled in, which has been accomplished and tested by @SHM, then we also implemented controlling Ecobee at the same time which was tested by @macjeff and confirmed working. For Ecobee users this is a viable option, although UDI is still working on getting API access restored, so if you eventually want the extra features of the API mode then you should stick with connecting the Ecobee plugin with this plugin.
As of 7/4/2026 the Standard and Professional use the same code base so please follow this post for information on both.
See README, CHANGELOG and CONFIG for more information.
If you have issues or questions create a new post in this sub-forum. But if it's a bug please enter it at HomeKit Plugin Issues so I can track it better, and if it has been discussed in the forum include a link to the post.
Please make sure you have done a recent Upgrade Packages: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#common-causes
Edited by Jimbo.Automates
  • 3 months later...
