eisy IoX HTTPS certificate expired
My eisy is now running:
  • OS 14.4-RELEASE-p6
  • IoX firmware 6.1.1
  • IoX UI 6.1.1
After upgrading packages and rebooting successfully, the certificate presented by the local IoX HTTPS endpoint on port 8443 remains:
  • Subject/issuer: O=UD, CN=polisy
  • Valid from May 30, 2024
  • Expired May 30, 2025
  • No Subject Alternative Name
The certificate was unchanged by the upgrade. I need a Raspberry Pi automation on the local network to call the IoX REST API using HTTPS with certificate verification enabled. I do not want to disable certificate verification.
What is the supported procedure for regenerating or renewing this eisy-managed IoX certificate and establishing verified local HTTPS access?
