September 9Sep 9 Some warnings if you migrate or install new using the Eisy-ui Plugins.if you use a devfile upload it to the data folder (you don't need to use a zip file anymore). I found that if you put it somewhere else, like in your admin folder, strange things happen. Like some of my devices did not show up, not all of them, just a few. I first thought it was a permissions thing, but just some of them?!?Check your programs using the old Admin, you may find some unloaded (yellow), where you need to update one line of your program and save again.Check all your scenes where you used Virtual devices. I have had to re-add mine due to how I transitioned. Do this from Admin(not eisy-ui), there is a new groups thing which is more complicated than regular scenes.Once done, it sticks but be warned, an inspection of all your devices may be necessaryCome back here with any learnings. This move to eisy-ui is a very good thing, but there are a few unintended consequences.tagging @bmercier , don't need anything, just feedback if all this makes sense. Its only Virtual which has had these issues.
