September 10Sep 10 We just purchased a home with ISY and UD, this is a large amount of information for me to understand, we had a garage motion detector battery die and i replaced it, with no look with it connecting t the network. I tried "link management" "Link Sensor" "Motion sensor II" I selected "add devices found in links and keep existing links" typed in the same numbers from previous and no dice. the funny thing is when i do that and press beep it beeps. it is so weird. thanks your help.
September 11Sep 11 @Mav2019 It sounds like you need to wake the motion detector up and then query it at the IOX. Another issue that I have had is that if it is a model with a 9 v battery, the connector may require re-tensioning. The connectors get bent out of shape when the battery is removed. I have replaced the batteries in all of my instion motion detectors with external power supplies because I got tired of the battery issues. I have had better luck with ZOOZ motion detectors, their batteries seem to last a long time.Congratulations on the new house and ISY.Enjoy the learning curve, it is definitely worth it in my opinion.
