September 14Sep 14 I created scenes in the AC with different powered levels for different dimmer devices but then when I run those scenes or execute programs which contain those scenes, the power level of those devices comes up to 100 percent ignoring the levels that I set. I would appreciate any and all help. Thank you.
September 14Sep 14 You probably didn't set the on levels for the devices in the sceneCan you post a screen shot of one of the scenes
September 14Sep 14 Author Thank you Techman for your prompt respons. Since I posted, I think I solved this issue. In the program I wrote to execute the scene, I had set the command to power the dimmers to “Fast On”. I changed the command to “On” and the program and scene work as expected.Thanks again for your help.
