Needing to authenticate daily
Hi,
Been using the ring plugin for quite a while and really appreciate it! Recently (past week or so) I have found that each day the plugin reports the need to reauthenticate. I do that and it works fine, but then within a day the same thing happens. What is really unfortunate is that I cannot authenticate on UDMobile and I often find it failing when I don't have quick access to a laptop.
Is anyone else seeing this or does anyone have any suggestions?
Good morning,
For what it's worth.
I am not using the ring plugin, but I do find myself having to reboot EISY-UI daily to keep my programs running. I believe that my issue is related to UD moving away from IOX and Java.
I have started to use EISY-UI with the understanding that it is still a work in progress; problems are a "FEATURE".
I have noticed that after reboot a program's next runtime looks good, then after that program event occurs, it's next runtime is out of whack or non existant. Again, after a reboot, the next run time is correct.
I am using the beta versions and enjoy looking daily for newer versions. I believe that my issues will clear up in time. Hopefully you will benefit as well.
I was comfortable with IOX, but the more I use EISY-UI the more I like it.
After this issue clears, I will look into the ring plugin.
Best of luck!
