September 29Sep 29 Just updated to 6.1.2 yesterday. I am sending many values from Home Assistant to MQTT to PG3 to the eISY. Seems complex, but it works very well. The update yesterday caused the only Analog value I am passing to not arrive into the PG3 interface.Here is the config for this sensor:- id: "waveradon1day" name: "waveradon1day" type: "analog" sensor_id: "A1" status_topic: "tele/waveradon1day/SENSOR" cmd_topic: "cmnd/waveradon/POWER"MQTT Explorer is showing a value of 3.76PG3 is showing 2.86All my other MQTT nodes, flag, raw, switch, Temp/Humid all are getting updated properly.Only this Analog Sensor is throwing this error. Something changed in this new update.PolyGlot Error message:2026-09-29 08:49:59.941 MQTT udi_interface.interface INFO interface:_message: Successfully set ep1sensor :: CLITEMP to 67.35 UOM 172026-09-29 08:50:00.073 MQTT udi_interface.interface INFO interface:_message: Successfully set ep1sensor :: CLIHUM to 43.87 UOM 222026-09-29 08:50:00.112 paho-mqtt-client- udi_interface ERROR Controller:_route_message_to_device: Failed to route message to device: 'in <string>' requires string as left operand, not dict2026-09-29 08:50:31.516 paho-mqtt-client- udi_interface ERROR Controller:_route_message_to_device: Failed to route message to device: 'in <string>' requires string as left operand, not dict
