Setting "OFF" to 10% or Less
I want to be able to not completely turn a Christmas tree off. 1-3% would be perfect. 10% I'd settle for.
There are some logisticals reasons why I would want this to work.
Currently, this is my program:
       Control 'Master Bedroom KeyLinc C' is not switched On
    Or-(
      |     Status  'Master Bedroom Christmas Tree' < 30%
      |  Or Status  'Master Bedroom Christmas Tree' is not On
       Set 'Master Bedroom Christmas Tree' 10%
Is there a better way to accomplish this?
Also while we're at it, is there any way to control the OFF ramp rate using ISY? I do not want to set the local control for the slow ramp rate.
Joe
Create a Scene and put the tree in it. Then you can select any level and rate you like. Instead of controlling the tree turn on the scene.
Sub-Routine:
Thanks. I knew I was missing the simple approach. I'm a newbie here and just getting into it. The problem...as you well know...is the deeper you get, the more you realized what you don't know.
Joe
Joe,
Welcome to the world of Insteon :D
Scenes are your friends 8)
Rand
