edfinley Posted September 12, 2010 Share Posted September 12, 2010 I have a morninglinc installed and talking to ISY and ELK. ELK is controlling it fine, but if it thinks the morninglinc is locked (i.e. ON) and I have a rule to lock it, nothing happens. Since the communication is only one way this sets us up for a trap. For example, my rule locks the morninglinc whenever the door closes. This works fine if ELK unlocks it. If I manually unlock it, it won't lock when the door closes, because it thinks it's already locked. If I go to the ISY web interface (which also sees it as locked) and send the lock "ON" command, it works. Is there a way I can get the ELK to send the command regardless of what it thinks the state is? Regards, Ed Link to comment Share on other sites More sharing options...
fitzpatri8 Posted September 12, 2010 Share Posted September 12, 2010 Would it work if you set up the Elk rule to first unlock it, then immediately re-lock it? Link to comment Share on other sites More sharing options...
edfinley Posted September 14, 2010 Author Share Posted September 14, 2010 Great idea. It seems to be working. I also thought of sending an unlock command anytime the door opens. That gets it back in sync also. Link to comment Share on other sites More sharing options...
Baypointe Posted September 23, 2010 Share Posted September 23, 2010 I have the same system and mine works great. Here is what I did. I have an EZIO that I am not using all output ports on it. You could use any Insteon device that is not in use as a trigger (i.e. plug in module). I can't think of a way that the elk can trigger a flag for the ISY. In Elk rules: Rule 1 Whenever front door becomes not secure and exit delay, any area is active Then turn on output 60 for 30 seconds Rule 2 Whenever Front door becomes secure and output 60 is on Then turn on "EXIO output 6" for 5 seconds ISY rules: If "EZIO output 6" is on Than turn on "Front door dead bolt" The 30 seconds is time to step out the door. Output 60 is used as a toggle and has no physical output attached. This is a great trick for many automation events. I like this as you can hear the door lock 2 seconds after door closes. I also have an Elk rule for leaving though garage door. Whenever exit delay, any area ends and "Front door" is secure Then turn on "EZIO output 6" for 5 seconds This makes sure that front door is always locked when system is armed. Hope this helps. Jim Link to comment Share on other sites More sharing options...
