Two Keypad lincs to one scene problem
I have two keypad lincs. The main button on each controls a two way light. I have the scene set with both buttons as controllers. Everything works fine if I use the keypads or if I used the scene on/off. However, if I use set the individual button on or off in the device menu, one works the light correct, the other never controls the light.
I'm lost on this one... Have I set something wrong or do I have my wiring backwards?
Can you expand on the physical set up. Two KPLs; each Main A is controlling a different load?, or the two KPL Main A buttons are connected to and trying to control the same load.
Also individual Main A button control through the Admin Console does not cause any Scene relationship to be involved. Turning On/Off Main A on KPL A does not cause Main A on KPL B to turn On/Off. Insteon does not work that way. If you want both switches to remain in sync when controlled from the ISY you must use the Scene to turn On/Off.
