Can't access isy
When i go in from icon in the network connections, or typing the address, or from isy's web page, or the links i found in the forums it opens a browers as usual but just hangs and comes back with xlm parse error http://192.168.1.102/desc then i click ok then error socket open failed java.net.sockettimeoutexception comes up i hit ok and it keeps going thru this cycle i reset the isy and cleared the java and rebooted the computer. i am stuck.
Jay
All it did was bring up isy finder box with cancel, add, remove. & refresh buttons and they don't do anything
well after about 10 to 15 mins it showed an adrress i double clicked it the admin panel opened and the same errors started popping up. i did get to login with my laptor but couldn't get anything to do anything it just sits there but from my destop i don't even get the login just errors once the window opens i also uninstalled java and reinstalled no difference
well i can't get the desktop to work still same problem i started using the laptop to do some changes and it was running very slow with errors of IO error:proxy device so i don't know what to think
just looked at my program summary and a lot of them say not loaded under activity and out of memory under status.
got no lights blinking and for the last hr have had no problems with the laptop but still same errors from my desktop i reset the isy
I have windows vista 32 bit service pack 2 i don't have any virus protection and the only firewall is the windows program just checked the firewall and the java is checked the same as java and my brultech i have been using tjis computer for the 2 months that i have had the isy with no problems. it worked yesterday morning then a few hrs later the problems started i believe it's 32 bit java it just says version 1.6 and it's been on the desktop for a couple of months. thinking something went wrong in it i uninstalled and reinstalled but no change
Found the problem the brultech had the same ip address as the isy even thought the isy was set for automatic dhcp i changed the address with ether config and it's been perfect this morning it's weird that the problems showed on 1 computer and not both.
for the help
Jay
