Need help with Notification scheme
I have my ISY programmed to send a text message to me in the event that my house's alarm is triggered. I've been trying to add additional programs to also send a text to inform me which zone had been breached. The alarm trigger program works without fail. It looks like this:
Program 'System Alarmed!!' is True
Send Notification to 'Home'
Set Scene 'Scenes / Outdoor Lights' Fast On
Wait 3 seconds
Set Scene 'Scenes / Interior Lights' Fast On
Then I wrote a program for each zone which looks like this:
Program '1 Front/Theater Door' is True
When the door/window is closed, the DSC interface makes the program tied to that zone False. When the zone is open, the DSC makes the zone's program True.
The above program (and all the other zone's similar programs) reside in a Folder with the constraint:
Folder Conditions for 'Alarmed Notification'
Add conditions to limit when programs in this folder are allowed to run.
For whatever reason, I get the first notification "DSC Alarmed!!" but I never get the additional text about which zone was breached. What am I doing wrong?
Since the zone opening occurs first (within a split second any way) then the alarm trips, I wonder if this might work:
And Folder 'Alarmed Notifications' is True
Tim
I think you are on to the issue, but it didn't work. I'll have to come up with something else.
How about removing the folder condition for Alarmed Notification. Then changing the program to:
And Program 'System Alarmed' is True
Wait 5 seconds
or possibly this way:
And Program 'System Armed Away' is True
Wait 5 seconds
Tim
This is my latest iteration of programming. I haven't been able to test it yet though.
I changed the If statement of the Folder to:
Program '*Armed Away' is True
For all of the zones except the front door which has an entry delay I merely wrote:
Program '10 Family Room North' is True
That should work because the alarm will be alarmed if any of those zones become true while the alarm is armed.
For the front door zone which has an entry delay:
Wait 30 seconds
Enable Program 'Front Door Breached'
That should cover the entry delay so I don't get a bunch of false notifications.
Then I wrote:
Run Program 'Front Door Toggle' (Else Path)
Which will send the notification if the alarm is set off. This program is in the Disabled state by default.
To toggle the state of the above program I wrote:
Disable Program 'Front Door Breached'
A little elaborate I know but hopefully, foolproof.
Hi Mitch236,
Looks good. The only thing that may cause a problem that I can see is the delay in the program:
Wait 30 seconds
If the Front/Theater Door is closed before the 30 seconds are up the program will turn back to false (as would the programs in my suggestions above). You may have to break the program into two.
Tim
You're right. I don't even need the delay, it should work fine without it.
