FAST ON Detection by ISY99 for Icon Dimmer - 2876DB
I have just started programming a number of Switchlinc / Icon dimmers and relays using FAST ON / OFF. However, it appears that with the Icon dimmer, 2876DB, the FAST commands are not detected by the ISY. In other words, when setting up a condition:
If Control "Upstairs Hall Lite" is switched Fast On
If the device, in this case, the Upstairs Hall Lite, is an Icon Relay (2876SB), or a Switchlinc relay (2476S) the ISY will let me set up this condition. However, if the device is an Icon dimmer, (2876DB), it will not show up in the list of devices when trying to set up a Control based condition.
It would appear that this is by design. Can someone tell me if this is true or am I screwing something up as usual?
Justin in Dallas
Justin,
Running 2.8.4 with ICON Dimmer 2876DB v39, I was able to define an If Control with Fast On and confirmed the Program works as expected.
Lee
