LarryC1116 Posted November 26, 2010 Share Posted November 26, 2010 I have been using an ISY-99i for my INSTEON newtork and decided to replace it with a SmartLinc (I think the South FL lighting hits may have caused my PLM or ISY-99i to get flakey) I can't seem to do the simple thing of getting my SmartLinc an IP address I am pretty well versed in networking, but this must be something simple Here are things I have done 1. Replaced the CAT5 cable connecting the SmartLinc to my router 2. Reset the SmartLinc (hold and then 5 taps) 3. Got a replacement SmartLinc - same problems 4. Upgraded my firmware in the router 5. Put my ADSL model in bridge mode 6. Cleared Java cache on my PC (thinking something with the ISY-99i was an issue) 7. Tried the SmartLinc in 3-4 different locations Some Observations 1. When I plug in SmartLinc I immediately get a bright blink then it goes dim 2. When I ping smartlinc.smarthome.com from my PC I see IP address 198.173.162.111 3. I have green link lights at both the SmartLinc and my router 4. I never see the device in my router's attached devices table 5. I left the SmartLinc connected to the router overnight - same result neither router seems to connect 6. When I go to http://smartlinc.smarthome.com and click "I'm at Home" I get the "cannot find a SmartLinc on your network (public IP address)" message 7. I tried #6 from multiple PCs - same result My Configuration 1. Embarq EQ-660R ADSL modem in bridge mode 2. NETGEAR ProSafe VPN Firewall Router FVS 318 - BUT no firewall is enabled nor are any VPN links 3. DHCP is turned on at the router and other devices function fine 4. I do have a few fixed assigned IP devices in the higher numbers that should not be an issue 5. I do have dyndns.org turned on in my router (shouldn't matter) Can you help me? Any queations? Larry Link to comment Share on other sites More sharing options...
LeeG Posted November 26, 2010 Share Posted November 26, 2010 For help with the SmartLinc post on the Smarthome forum. Link to comment Share on other sites More sharing options...
LarryC1116 Posted November 27, 2010 Author Share Posted November 27, 2010 Thanks Link to comment Share on other sites More sharing options...
