Device won't link!
Help!
I just purchased an ISY-99i/IR (with the PLM + 1 access point) plus 3 Insteon dimmer devices. I am a long-time X10 user, and looking forward to migrating over to Insteon and greater control with the ISY. I am having some difficulties though:
I had no trouble linking and controlling 2 dimmer devices (2476DH and2486D) with the ISY, but have not been able to link the 3rd dimmer (2476D). The automatic linking that worked easily for the first 2 devices did not work at all for the 3rd (no error, nothing) so I tried the manual linking it (i.e. "New INSTEON device") and entering the address, but get back an error "Failed writing the Highwater mark" and "Node not added - failed removing links". The event log contains a message ""Failed getting engine version, reverting to i1", not sure if that is relevant. I have tried moving the ISY/PLM to another location. What is really odd is that all 3 dimmer devices are located side by side in the same electrical gang box, and 2 work but 1 doesn't, so it seems hard to believe that there is an interference problem. I even switched the problem dimmer with one that is working and it still doesn't work with the other device still works fine. I tried a factory reset on the device, but did not help. The LEDs seem to indicate that it is going into controller linking mode rather than linking as a responder when I hold down the button to link. Note that it works fine as a stand-alone dimmer but won't link to the ISY. Could this dimmer be faulty?
On an unrelated note: How do I unlink a device from the ISY? According to Insteon device doc, to unlink I need to put the controller into unlinking mode, but can't figure out how to do that in the ISY console.
Thanks for any help
Erik
Hi Erik,
It certainly sounds like you have done all the tests on the switch. That is unusual for a new device.
To unlink a device from the ISY right-click it and select Remove.
Rand
Help!
Thanks for any help
Erik
