How to best use Climate Module to control HVAC?
I live in S. Florida which is normally quite warm. The past week though, and the temps have dropped into the 40's and I've had to consider heating in my HVAC programming. I wrote a new program to control my HVAC and tied the If statement to the Climate Module. However, because the Module polls every minute, I've created a massive amount of network traffic as my program updates the Venstar T-stats every minute (I have four).
Here's a copy of one of the HVAC programs. For now, I've changed the polling interval to 900 seconds to lessen the traffic but I'm sure there is a better solution as the one I'm using doesn't allow for local changes to the T-stat as the ISY will reset it back to program settings once the Climate Module polls and runs the program.
The Heater On program: (I had to replace the "less than" sign with the wording as it doesn't post correctly otherwise)
From 7:30:00PM
To 8:00:00AM (next day)
And Module 'Climate' Temperature (less than) 60 °F
Set 'Indoor / Thermostats / Master Suite / HVAC Master Suite' Mode Auto
Wait 5 seconds
Set 'Indoor / Thermostats / Master Suite / HVAC Master Suite' Fan Auto
Wait 5 seconds
Set 'Indoor / Thermostats / Master Suite / HVAC Master Suite' 76° (Heat Setpoint)
Wait 5 seconds
Set 'Indoor / Thermostats / Master Suite / HVAC Master Suite' 82° (Cool Setpoint)
Set 'Indoor / Thermostats / Master Suite / HVAC Master Suite' 80° (Cool Setpoint)
Wait 5 seconds
Set 'Indoor / Thermostats / Master Suite / HVAC Master Suite' 40° (Heat Setpoint)
Wait 5 seconds
Wait 5 seconds
The A/C On program:
From 7:30:00PM
And Module 'Climate' Temperature >= 60 °F
Wait 5 seconds
Wait 5 seconds
Set 'Indoor / Thermostats / Master Suite / HVAC Master Suite' 60° (Heat Setpoint)
Wait 5 seconds
Set 'Indoor / Thermostats / Master Suite / HVAC Master Suite' 77° (Cool Setpoint)
Wait 5 seconds
Wait 5 seconds
Wait 5 seconds
I realized one problem. I removed the Else statement from both programs. That was duplicative. So please ignore the Else statemtents in the above programs!
Hi mitch236,
This is similar to this Wiki article: ISY-99i_Series_INSTEON:Light_Data_Program in that you only want to change the settings once for each transition. This will also allow you to make local changes that won't be changed by the ISY until the temperature crosses the threshold again. Adding a 10 minute Wait keeps the settings from cycling too often.
You can create scenes for the thermostats rather than making specific settings in your programs. For example you can create a Cold scene and a Warm scene, each of which contains the setpoints, fan state, and thermostat modes.
Wait to Change Thermos
       Wait  10 minutes
       Set Scene 'Thermostat Warm' On
       Wait  10 minutes
       Set Scene 'Thermostat Cold' On
Create a new folder with the time constraints.
Folder Conditions for 'Night Time'
Add conditions to limit when programs in this folder are allowed to run.
       From     7:30:00PM
And within this folder are two programs.
Cold
       Module 'Climate' Temperature < 60 °F
   And Program 'Wait to Change Thermos' is True
       Run Program 'Wait to Change Thermos' (Else Path)
Warm
   And Program 'Wait to Change Thermos' is False
       Run Program 'Wait to Change Thermos' (Then Path)
Rand
