No port info in Help/About
Greetings,
I am just starting my foray into the world Insteon/ISY99. I am coming from a basic X10 setup. I have the ISY99 connected to an Apple Time Capsule. When I select Help/About I get the the ISY identifier, an IP of 10.0.1.XX but no http or port#.
Is this par for the course on TC's (require port forwarding to 443) or is there something I am overlooking? I would really like to get the internet connection up and running. Thanks
Hello mjtyson,
I believe the Time Capsule is nearly the same as an Airport.
Let us know if this procedure works for you: Airport Extreme Port Forwarding
Thank you,
Rand
Greetings,
