Red device labels on Thermostat Heat, Cold, and Fan
Greetings,
After installing a T-1900 with Insteon module I end up with a blue label for the Thermostat main but red labels for the Cool, Fan, and Heat. Everything appears to be working without any issues. Does this indicate a problem or is this normal behaviour? Thanks again,
Red nodes represent Controllers from the device perspective. Such as the buttons on a Controlinc. The device sends messages to the Red nodes. The Blue nodes represent Responders from the device perspective. Such as the output relay(s) on an I/O Linc or EZIOxx device. These device nodes receive messages from other Controllers (such as the ISY/PLM). KeypadLinc buttons appear in Red. They can be a Controller or a Responder from the device perspective. Messages come to the Red KPL nodes when a KPL button is pressed. Because these nodes are also Responders, messages can be sent to the Red KPL nodes to turn the KPL LED On and Off. The color scheme should be consistent across all the nodes in the My Lighting tree.
