January 31, 201115 yr ELA Sorry about the nomenclature confusion. As Brian has already noted, The Level 1,2,3 at 2.7.15 was changed to text equivalent in the 2.8.x images. Yes, Peek reads 1 byte of memory, Poke writes 1 byte of memory, The Set MSB (Most Significant Byte) establishes the high order byte of memory address. Peek establishes the low order byte of memory address and reads 1 byte from memory. Optionally the byte of memory is subsequently written using Poke. Takes quite a few of these commands strung together to read/write an 8 byte link record 1 byte at a time. The newer ALDB 2F Extended command reads or writes an 8 byte link record with 1 command. There can be some quirks with the ALDB command which is why the ISY will generally use the Peek/Poke method for link record management. Lee
February 1, 201115 yr Author Thanks for your offer to interpret Lee, Here is a rather lengthy session where I unlinked and then relinked again. Can we attach files here or is cut and paste the only way to share these files? Sorry about the length: Mon 01/31/2011 06:48:43 PM : [15 55 0 1 ] Link 1 : 0FF0 [62010F9E56FF1F01] Saving [62..............] Mon 01/31/2011 06:48:43 PM : [MNG-LNK-RSP ] 02 6F 80 E2 00 15 55 00 01 1E 39 06 Mon 01/31/2011 06:48:43 PM : [Old Front Entrance Sw - Obsol] Start : Removing device from ISY Mon 01/31/2011 06:48:43 PM : [15 55 0 1 ] Using engine version i1 for 'Old Front Entrance Sw - Obsol' Mon 01/31/2011 06:48:43 PM : [15 55 0 1 ] Link 1 : 0FF0 [62010F9E56FF1F01] Writing [62..............] Mon 01/31/2011 06:48:44 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:48:44 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:48:44 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:48:44 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B F0 06 PEEK (F0) Mon 01/31/2011 06:48:44 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B E2 PEEK (E2) Mon 01/31/2011 06:48:44 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:48:45 PM : [iNST-ACK ] 02 62 15.55.00 0F 29 62 06 POKE (62) Mon 01/31/2011 06:48:45 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 29 62 POKE (62) Mon 01/31/2011 06:48:45 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:48:45 PM : [MNG-LNK-RSP ] 02 6F 80 A2 01 15 55 00 01 1E 39 06 Mon 01/31/2011 06:48:45 PM : [PLM ] Group 1 : Deleting Responder Link matching [15 55 0 1 ] Link 1 : 0FF0 [62010F9E56FF1F01] Mon 01/31/2011 06:48:45 PM : [Old Front Entrance Sw - Obsol] Finish : Removing from ISY was Successful Mon 01/31/2011 06:50:31 PM : ---- Initializing the linked devices ---- Mon 01/31/2011 06:50:31 PM : ---- All Linked Devices are now initialized ---- Mon 01/31/2011 06:50:31 PM : ---- Add remaining devices ---- Mon 01/31/2011 06:50:31 PM : [ 15 55 0 1] Removing all links Mon 01/31/2011 06:50:31 PM : [15 55 0 1 ] Querying engine version Mon 01/31/2011 06:50:31 PM : [iNST-ACK ] 02 62 15.55.00 0F 0D 00 06 (00) Mon 01/31/2011 06:50:31 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 0D 01 (01) Mon 01/31/2011 06:50:31 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:31 PM : [15 55 0 1 ] Retrieved engine version is i2 Mon 01/31/2011 06:50:31 PM : [15 55 0 1 ] Calibrating engine version ensuring support for i2 Mon 01/31/2011 06:50:31 PM : [iNST-ACK ] 02 62 15.55.00 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00) Mon 01/31/2011 06:50:31 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2F 00 (00) Mon 01/31/2011 06:50:31 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:32 PM : [iNST-ERX ] 02 51 15 55 00 0F 9E 56 11 2F 00 01 01 00 FF 01 A2 00 0F 9E 56 FF 1F 00 00 Mon 01/31/2011 06:50:32 PM : [Extended-Direct][15.55.00-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Mon 01/31/2011 06:50:32 PM : [Ext. Msg. Handler] Duplicate response: ignored Mon 01/31/2011 06:50:41 PM : [iNST-ACK ] 02 62 15.55.00 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00) Mon 01/31/2011 06:50:41 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2F 00 (00) Mon 01/31/2011 06:50:41 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:41 PM : [iNST-ERX ] 02 51 15 55 00 0F 9E 56 11 2F 00 01 01 00 FF 01 A2 00 0F 9E 56 FF 1F 00 00 Mon 01/31/2011 06:50:41 PM : [Extended-Direct][15.55.00-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Mon 01/31/2011 06:50:41 PM : [Ext. Msg. Handler] Duplicate response: ignored Mon 01/31/2011 06:50:50 PM : [iNST-ACK ] 02 62 15.55.00 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00) Mon 01/31/2011 06:50:51 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2F 00 (00) Mon 01/31/2011 06:50:51 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:51 PM : [iNST-ERX ] 02 51 15 55 00 0F 9E 56 11 2F 00 01 01 00 FF 01 A2 00 0F 9E 56 FF 1F 00 00 Mon 01/31/2011 06:50:51 PM : [Extended-Direct][15.55.00-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Mon 01/31/2011 06:50:51 PM : [Ext. Msg. Handler] Duplicate response: ignored Mon 01/31/2011 06:50:55 PM : [15 55 0 1 ] i2 data transfer commands do not work. Reverting to i1 Mon 01/31/2011 06:50:55 PM : [15 55 0 1 ] Using engine version i1 Mon 01/31/2011 06:50:55 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:50:56 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:50:56 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:56 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B F8 06 PEEK (F8) Mon 01/31/2011 06:50:56 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B A2 PEEK (A2) Mon 01/31/2011 06:50:56 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:56 PM : [iNST-ACK ] 02 62 15.55.00 0F 29 00 06 POKE (00) Mon 01/31/2011 06:50:57 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 29 00 POKE (00) Mon 01/31/2011 06:50:57 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:57 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:50:57 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:50:57 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:57 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B F0 06 PEEK (F0) Mon 01/31/2011 06:50:58 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 62 PEEK (62) Mon 01/31/2011 06:50:58 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:58 PM : [iNST-ACK ] 02 62 15.55.00 0F 29 00 06 POKE (00) Mon 01/31/2011 06:50:58 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 29 00 POKE (00) Mon 01/31/2011 06:50:58 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:58 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:50:59 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:50:59 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:59 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B E8 06 PEEK (E8) Mon 01/31/2011 06:50:59 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 00 PEEK (00) Mon 01/31/2011 06:50:59 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:50:59 PM : [ 15 55 0 1] Adding device to ISY Mon 01/31/2011 06:50:59 PM : [iNST-ACK ] 02 62 15.55.00 0F 10 00 06 ID-REQ (00) Mon 01/31/2011 06:51:00 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 10 00 ID-REQ (00) Mon 01/31/2011 06:51:00 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:00 PM : [iNST-SRX ] 02 50 15.55.00 01.1E.39 8B 01 00 (00) Mon 01/31/2011 06:51:00 PM : [standard-Broadcast][15.55.00-->01.1E.39] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:00 PM : [old front hall light - obsole] Start : Adding device to ISY Mon 01/31/2011 06:51:00 PM : [old front hall light - obsole] Finish : Adding device to ISY was Successful Mon 01/31/2011 06:51:00 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 15 55 00 01 1E 39 06 Mon 01/31/2011 06:51:00 PM : [15 55 0 1 ] Link 0 : 0FF8 [A2000F9E56FF1F00] Saving [A2000F9E56FF1F00] Mon 01/31/2011 06:51:00 PM : [15 55 0 1 ] Link 1 : 0FF0 [E2010F9E56FF1F01] Saving [E2010F9E56FF1F01] Mon 01/31/2011 06:51:00 PM : [15 55 0 1 ] Using engine version i1 for 'old front hall light - obsole' Mon 01/31/2011 06:51:00 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 00 06 SET-MSB(00) Mon 01/31/2011 06:51:01 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 00 SET-MSB(00) Mon 01/31/2011 06:51:01 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:01 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B 32 06 PEEK (32) Mon 01/31/2011 06:51:01 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B FE PEEK (FE) Mon 01/31/2011 06:51:01 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:01 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 00 06 SET-MSB(00) Mon 01/31/2011 06:51:02 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 00 SET-MSB(00) Mon 01/31/2011 06:51:02 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:02 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B 21 06 PEEK (21) Mon 01/31/2011 06:51:02 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 19 PEEK (19) Mon 01/31/2011 06:51:02 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:02 PM : [ 15 55 0 1] OL 255 Mon 01/31/2011 06:51:02 PM : [ 15 55 0 1] RR 25 Mon 01/31/2011 06:51:02 PM : [iNST-ACK ] 02 62 15.55.00 0F 19 00 06 LTSREQ (LIGHT) Mon 01/31/2011 06:51:03 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 03 FF (FF) Mon 01/31/2011 06:51:03 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:03 PM : [ 15 55 0 1] ST 255 Mon 01/31/2011 06:51:03 PM : [ 15 55 0 1] OL 255 Mon 01/31/2011 06:51:03 PM : [ 15 55 0 1] RR 25 Mon 01/31/2011 06:51:04 PM : [ 15 55 0 1] Device added to ISY Mon 01/31/2011 06:51:04 PM : ---- All Remaining Device Added ---- Mon 01/31/2011 06:51:04 PM : [iNST-ACK ] 02 62 15.55.00 0F 19 00 06 LTSREQ (LIGHT) Mon 01/31/2011 06:51:05 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 03 FF (FF) Mon 01/31/2011 06:51:05 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:05 PM : [ 15 55 0 1] ST 255 Mon 01/31/2011 06:51:05 PM : [ 15 55 0 1] OL 255 Mon 01/31/2011 06:51:05 PM : [ 15 55 0 1] RR 25 Mon 01/31/2011 06:51:05 PM : [15 55 0 1 ] Using engine version i1 for 'old front hall light - obsole' Mon 01/31/2011 06:51:05 PM : [15 55 0 1 ] Link 0 : 0FF8 [A2000F9E56FF1F00] Writing [A2000F9E56FF1F00] Mon 01/31/2011 06:51:05 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:51:05 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:51:05 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:05 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B F8 06 PEEK (F8) Mon 01/31/2011 06:51:06 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 00 PEEK (00) Mon 01/31/2011 06:51:06 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:06 PM : [iNST-ACK ] 02 62 15.55.00 0F 29 A2 06 POKE (A2) Mon 01/31/2011 06:51:06 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 29 A2 POKE (A2) Mon 01/31/2011 06:51:06 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:06 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B F9 06 PEEK (F9) Mon 01/31/2011 06:51:07 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 00 PEEK (00) Mon 01/31/2011 06:51:07 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:07 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:51:07 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:51:07 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:07 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B FA 06 PEEK (FA) Mon 01/31/2011 06:51:08 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 0F PEEK (0F) Mon 01/31/2011 06:51:08 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:08 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:51:08 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:51:08 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:08 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B FB 06 PEEK (FB) Mon 01/31/2011 06:51:09 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 9E PEEK (9E) Mon 01/31/2011 06:51:09 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:09 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:51:09 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:51:09 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:09 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B FC 06 PEEK (FC) Mon 01/31/2011 06:51:10 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 56 PEEK (56) Mon 01/31/2011 06:51:10 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:10 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:51:10 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:51:10 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:10 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B FD 06 PEEK (FD) Mon 01/31/2011 06:51:11 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B FF PEEK (FF) Mon 01/31/2011 06:51:11 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:11 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:51:11 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:51:11 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:11 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B FE 06 PEEK (FE) Mon 01/31/2011 06:51:12 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 1F PEEK (1F) Mon 01/31/2011 06:51:12 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:12 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:51:12 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:51:12 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:12 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B FF 06 PEEK (FF) Mon 01/31/2011 06:51:13 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 00 PEEK (00) Mon 01/31/2011 06:51:13 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:13 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 15 55 00 01 1E 39 15 Mon 01/31/2011 06:51:13 PM : [PLM ] Group 0 : Writing Controller Link matching [15 55 0 1 ] Link 0 : 0FF8 [A2000F9E56FF1F00] Mon 01/31/2011 06:51:13 PM : [15 55 0 1 ] Using engine version i1 for 'old front hall light - obsole' Mon 01/31/2011 06:51:13 PM : [15 55 0 1 ] Link 1 : 0FF0 [E2010F9E56FF1F01] Writing [E2010F9E56FF1F01] Mon 01/31/2011 06:51:13 PM : [iNST-ACK ] 02 62 15.55.00 0F 28 0F 06 SET-MSB(0F) Mon 01/31/2011 06:51:14 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 28 0F SET-MSB(0F) Mon 01/31/2011 06:51:14 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:14 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B F0 06 PEEK (F0) Mon 01/31/2011 06:51:14 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 00 PEEK (00) Mon 01/31/2011 06:51:14 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:14 PM : [iNST-ACK ] 02 62 15.55.00 0F 29 E2 06 POKE (E2) Mon 01/31/2011 06:51:15 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 29 E2 POKE (E2) Mon 01/31/2011 06:51:15 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/31/2011 06:51:15 PM : [iNST-ACK ] 02 62 15.55.00 0F 2B F1 06 PEEK (F1) Mon 01/31/2011 06:51:15 PM : [iNST-SRX ] 02 50 15.55.00 0F.9E.56 2B 2B 01 PEEK (01) Mon 01/31/2011 06:51:15 PM : [standard-Direct Ack][15.55.00-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
February 1, 201115 yr ELA In this case the Extended ALDB commands are working for this device. However, as I mentioned before the ISY goes back to the Peek/Poke method for all but the Motion Sensor and Triggerlinc. Mon 01/31/2011 06:50:32 PM : [iNST-ERX ] 02 51 15 55 00 0F 9E 56 11 2F 00 01 01 00 FF 01 A2 00 0F 9E 56 FF 1F 00 00 Mon 01/31/2011 06:50:41 PM : [iNST-ERX ] 02 51 15 55 00 0F 9E 56 11 2F 00 01 01 00 FF 01 A2 00 0F 9E 56 FF 1F 00 00 Mon 01/31/2011 06:50:51 PM : [iNST-ERX ] 02 51 15 55 00 0F 9E 56 11 2F 00 01 01 00 FF 01 A2 00 0F 9E 56 FF 1F 00 00 This is the link record that is being returned. A2 00 0F 9E 56 FF 1F 00 Lee
