Recircilating Pump
I have a hot water recirculating pump that has been running 24x7. I qant to automate it to run off when not needed which is basicaly time and security system based.
1)Program Turns unit off at 10:15 pm
2)Program Turns unit on at 5:30 am
3)Turns unit Off at 9:30am MTWThF if "Away from Home" is True
4)Turns Unit on at 4:30pm MTWThF
I want to do 5th program/update existing program to turn unit on if I get home early through the work week. That is to say ... it is it is between 9:31am - 4:29 pm MTWThF and "Away from Home" becomes false.
What is the most straight forward ISY programing method to accomplish this task? The old school programming methods I learned 25 years ago blind me to the elegant methods possible within the ISY event/program construct (which is fantastic).
Was not near ISY when I posted but this is what I came up with... Look good?
On Mon, Tue, Wed, Thu, Fri
From 9:29:00AM
To 4:29:00PM (same day)
And Program 'Security:Away from Home Status' is False
Set 'Basement / Basement:HotH2ORecirculate' On
