3 way switch using a keypadlinc and a dimmer
I thought I read somewhere that you can use a keypadlinc and a dimmer in a 3 way switch situation. I tried doing that and I'm about half way there. I may just need some help. I also am using a ISY 99 to program buttons on the KPL.
I wired everthing up using the dimmer as the secondary and the KPL as the primary. The Master on/off on the KPL does turn on and off the light. The secondary is powered and is seen in the ISY program but the switch alone does nothing.
Using the ISY, how can I program this to turn on and off the load on the KPL? Perhaps this is in the manual. I'll go take a look.
Thanks for any direction and hints.
Define an ISY Scene. Add the SwitchLinc and KeypadLinc load control button (ON or Main) as Controllers of the Scene. When the Scene has been written to both devices they will be cross-linked. Either device will control the load and the LEDs will stay in sync.
