RemoteLinc and EZIO40
The v.28 is the latest EZIOxx firmware.
If the Set button link is still active use the SHN Utility and display the link records using "Manage Device Links". First use the Links Database Size: Small option and then the Large option to see which one (or both) display the Set button link. The Set button link location (Small or Large) identifies where the EXIO4O internal PLM expects the link records to reside.
The event trace of adding an EZIO4O node to an ISY Scene will show where the ISY is writing link records. The New INSTEON Device with the specific Device Type of EZIO4O causes the ISY to run an algorithm that determines the internal PLM memory size. The ISY writes link records based on the internal PLM memory size.
When ISY Scenes do not work it is usually a conflict between the size of the internal PLM memory versus where the internal PLM is actually writing records. A few years back some EZIOxx devices were shipped with large PLM memory but PLMs that used the memory as though it was the small memory model. That combination does not work with the ISY. They have not been shipping for a long time so a new EZIO4O should not have that problem. If this is an EZIO4O that was returned to SHN for firmware update it could have the latest firmware (which it does have) but an older PLM.
By comparing were the ISY is writing link records versus where the PLM Set button is writing link records a memory size issue can be determined.
EDIT: I've added two new EZIOxx devices this morning. Neither is an EZIO4O but both are at the same v.28 firmware level and have new PLMs with large memory. The ISY 3.1.17 successfully created Scenes with the EZIOxx nodes as Responders and the output relays responded correctly. Although not an absolute the EZIOxx addresses are 19.BD.xx
I reset the EZI to defaults and added again to ISY. This is the log when I added the EZIO40 to the ISY and added it to a scene. Gate-4 was added to "Open Gate" Scene. When the scene is activated the EZIO40 does not activate, however if I turn the only device to ON it operates.
Thu 03/08/2012 09:43:20 PM : ---- Initializing the linked devices ----
Thu 03/08/2012 09:43:20 PM : ---- All Linked Devices are now initialized ----
Thu 03/08/2012 09:43:20 PM : ---- Add remaining devices ----
Thu 03/08/2012 09:43:20 PM : [1 72 18 1 ] Calculating EZxx Address Offset
Thu 03/08/2012 09:43:20 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:20 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:43:21 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:43:21 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:21 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:21 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:43:21 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:21 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F)
Thu 03/08/2012 09:43:22 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F)
Thu 03/08/2012 09:43:22 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:22 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:22 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B FF PEEK (FF)
Thu 03/08/2012 09:43:22 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:22 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:43:23 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:43:23 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:23 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:23 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:43:23 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:23 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:43:23 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:43:24 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:24 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:24 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:43:24 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 01 06 POKE (01)
Thu 03/08/2012 09:43:24 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 01 POKE (01)
Thu 03/08/2012 09:43:24 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:25 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F)
Thu 03/08/2012 09:43:25 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F)
Thu 03/08/2012 09:43:25 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:25 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:25 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B FF PEEK (FF)
Thu 03/08/2012 09:43:26 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 02 06 POKE (02)
Thu 03/08/2012 09:43:26 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 02 POKE (02)
Thu 03/08/2012 09:43:26 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:26 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:26 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:43:26 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:43:27 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:27 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:43:27 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:27 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 03 06 POKE (03)
Thu 03/08/2012 09:43:27 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 03 POKE (03)
Thu 03/08/2012 09:43:27 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:28 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:43:28 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:43:28 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:28 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:28 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 01 PEEK (01)
Thu 03/08/2012 09:43:28 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:29 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F)
Thu 03/08/2012 09:43:29 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F)
Thu 03/08/2012 09:43:29 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:29 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:29 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 02 PEEK (02)
Thu 03/08/2012 09:43:29 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:30 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:43:30 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:43:30 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:30 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:30 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03)
Thu 03/08/2012 09:43:30 PM : [1 72 18 1 ] EZxx Address Offset at 3FFF
Thu 03/08/2012 09:43:30 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:31 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:43:31 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:43:31 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:31 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:31 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 01 PEEK (01)
Thu 03/08/2012 09:43:32 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 00 06 POKE (00)
Thu 03/08/2012 09:43:32 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 00 POKE (00)
Thu 03/08/2012 09:43:32 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:32 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:32 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F)
Thu 03/08/2012 09:43:32 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F)
Thu 03/08/2012 09:43:33 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:33 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 02 PEEK (02)
Thu 03/08/2012 09:43:33 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:33 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 FF 06 POKE (FF)
Thu 03/08/2012 09:43:33 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 FF POKE (FF)
Thu 03/08/2012 09:43:33 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:43:34 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:43:34 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:43:34 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:34 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:43:34 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03)
Thu 03/08/2012 09:43:35 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 00 06 POKE (00)
Thu 03/08/2012 09:43:35 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 00 POKE (00)
Thu 03/08/2012 09:43:35 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:35 PM : [ 1 72 18 1] Writing High Water Mark at Link 0
Thu 03/08/2012 09:43:35 PM : [1 72 18 1 ] Querying engine version
Thu 03/08/2012 09:43:35 PM : [iNST-ACK ] 02 62 01.72.18 0F 0D 00 06 (00)
Thu 03/08/2012 09:43:35 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 0D 01 (01)
Thu 03/08/2012 09:43:35 PM : [1 72 18 1 ] Retrieved engine version is i2
Thu 03/08/2012 09:43:35 PM : [1 72 18 1 ] Calibrating engine version ensuring support for i2
Thu 03/08/2012 09:43:35 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:43:36 PM : [iNST-ACK ] 02 62 01.72.18 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Thu 03/08/2012 09:43:36 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2F 00 (00)
Thu 03/08/2012 09:43:36 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:45 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:43:45 PM : [iNST-ACK ] 02 62 01.72.18 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Thu 03/08/2012 09:43:45 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2F 00 (00)
Thu 03/08/2012 09:43:45 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:54 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:43:54 PM : [iNST-ACK ] 02 62 01.72.18 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Thu 03/08/2012 09:43:55 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2F 00 (00)
Thu 03/08/2012 09:43:55 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:59 PM : [1 72 18 1 ] i2 data transfer commands do not work. Reverting to i1
Thu 03/08/2012 09:43:59 PM : [1 72 18 1 ] Using engine version i1
Thu 03/08/2012 09:43:59 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:43:59 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:43:59 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:43:59 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:43:59 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F8 06 PEEK (F8)
Thu 03/08/2012 09:44:00 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:44:00 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:00 PM : [ 1 72 18 1] Adding device to ISY t=07.08.0000
Thu 03/08/2012 09:44:00 PM : [1 72 18 1 ] Start : Adding device to ISY
Thu 03/08/2012 09:44:00 PM : [1 72 18 1 ] Finish : Adding device to ISY was Successful
Thu 03/08/2012 09:44:00 PM : [1 72 18 1 ] Calculating EZxx Address Offset
Thu 03/08/2012 09:44:00 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:00 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:44:00 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:44:00 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:01 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:44:01 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:01 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:01 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F)
Thu 03/08/2012 09:44:01 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F)
Thu 03/08/2012 09:44:01 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:02 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B FF PEEK (FF)
Thu 03/08/2012 09:44:02 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:02 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:02 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:44:02 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:44:02 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:03 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:44:03 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:03 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:03 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:44:03 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:44:03 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:04 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 01 06 POKE (01)
Thu 03/08/2012 09:44:04 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 01 POKE (01)
Thu 03/08/2012 09:44:04 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:04 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:04 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F)
Thu 03/08/2012 09:44:04 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F)
Thu 03/08/2012 09:44:05 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:05 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B FF PEEK (FF)
Thu 03/08/2012 09:44:05 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:05 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 02 06 POKE (02)
Thu 03/08/2012 09:44:05 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 02 POKE (02)
Thu 03/08/2012 09:44:05 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:06 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:44:06 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:44:06 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:06 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:06 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:44:07 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 03 06 POKE (03)
Thu 03/08/2012 09:44:07 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 03 POKE (03)
Thu 03/08/2012 09:44:07 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:07 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:07 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:44:07 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:44:08 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:08 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 01 PEEK (01)
Thu 03/08/2012 09:44:08 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:08 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:08 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F)
Thu 03/08/2012 09:44:08 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F)
Thu 03/08/2012 09:44:09 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:09 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 02 PEEK (02)
Thu 03/08/2012 09:44:09 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:09 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:09 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:44:09 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:44:10 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:10 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03)
Thu 03/08/2012 09:44:10 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:10 PM : [1 72 18 1 ] EZxx Address Offset at 3FFF
Thu 03/08/2012 09:44:10 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:10 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:44:10 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:44:11 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:11 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 01 PEEK (01)
Thu 03/08/2012 09:44:11 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:11 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 00 06 POKE (00)
Thu 03/08/2012 09:44:11 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 00 POKE (00)
Thu 03/08/2012 09:44:11 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:12 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F)
Thu 03/08/2012 09:44:12 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F)
Thu 03/08/2012 09:44:12 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:12 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:12 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 02 PEEK (02)
Thu 03/08/2012 09:44:13 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 FF 06 POKE (FF)
Thu 03/08/2012 09:44:13 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 FF POKE (FF)
Thu 03/08/2012 09:44:13 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:13 PM : [1 72 18 1 ] EZxx start address at 0x0FFF
Thu 03/08/2012 09:44:13 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:44:13 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:44:14 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:44:14 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03)
Thu 03/08/2012 09:44:14 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:14 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 00 06 POKE (00)
Thu 03/08/2012 09:44:14 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 00 POKE (00)
Thu 03/08/2012 09:44:14 PM : [1 72 18 1 ] Calculating EZxx Address Offset
Thu 03/08/2012 09:44:15 PM : [iNST-ACK ] 02 62 01.72.18 0F 4D 44 06 (44)
Thu 03/08/2012 09:44:15 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 4D 44 (44)
Thu 03/08/2012 09:44:15 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:15 PM : [iNST-ACK ] 02 62 01.72.18 0F 4F 02 06 IOCTL (QUERY)
Thu 03/08/2012 09:44:15 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 4F 00 IOCTL (00)
Thu 03/08/2012 09:44:15 PM : [ 1 72 18 1] ST 0
Thu 03/08/2012 09:44:16 PM : [iNST-ACK ] 02 62 01.72.18 0F 49 00 06 RINPUT (00)
Thu 03/08/2012 09:44:16 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 49 00 RINPUT (00)
Thu 03/08/2012 09:44:16 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:16 PM : [1 72 18 2 ] Start : Adding device to ISY
Thu 03/08/2012 09:44:16 PM : [1 72 18 2 ] Finish : Adding device to ISY was Successful
Thu 03/08/2012 09:44:16 PM : [1 72 18 2 ] Calculating EZxx Address Offset
Thu 03/08/2012 09:44:16 PM : [1 72 18 3 ] Start : Adding device to ISY
Thu 03/08/2012 09:44:16 PM : [1 72 18 3 ] Finish : Adding device to ISY was Successful
Thu 03/08/2012 09:44:16 PM : [1 72 18 3 ] Calculating EZxx Address Offset
Thu 03/08/2012 09:44:16 PM : [1 72 18 4 ] Start : Adding device to ISY
Thu 03/08/2012 09:44:16 PM : [1 72 18 4 ] Finish : Adding device to ISY was Successful
Thu 03/08/2012 09:44:16 PM : [1 72 18 4 ] Calculating EZxx Address Offset
Thu 03/08/2012 09:44:17 PM : [1 72 18 1 ] Device added to ISY
Thu 03/08/2012 09:44:17 PM : ---- All Remaining Device Added ----
Thu 03/08/2012 09:44:17 PM : [iNST-ACK ] 02 62 01.72.18 0F 4F 02 06 IOCTL (QUERY)
Thu 03/08/2012 09:44:18 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 4F 00 IOCTL (00)
Thu 03/08/2012 09:44:18 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:44:18 PM : [ 1 72 18 1] ST 0
Thu 03/08/2012 09:44:18 PM : [ 1 72 18 2] ST 0
Thu 03/08/2012 09:44:18 PM : [ 1 72 18 3] ST 0
Thu 03/08/2012 09:44:18 PM : [ 1 72 18 4] ST 0
Thu 03/08/2012 09:44:18 PM : [iNST-ACK ] 02 62 01.72.18 0F 49 00 06 RINPUT (00)
Thu 03/08/2012 09:44:18 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 49 00 RINPUT (00)
Thu 03/08/2012 09:44:18 PM : [All ] Writing 0 bytes to devices
Thu 03/08/2012 09:45:32 PM : [Gate - 4] Start : Adding to scene 'Open Gate'
Thu 03/08/2012 09:45:32 PM : [Gate - 4] Making 'Open Gate' a Controller
Thu 03/08/2012 09:45:32 PM : [MNG-LNK-RSP ] 02 6F 40 E2 15 01 72 18 07 08 00 06
Thu 03/08/2012 09:45:32 PM : [1 72 18 4 ] Link 0 : 0FF8 [A2151982E7000003] Saving [A2151982E7000003]
Thu 03/08/2012 09:45:32 PM : [Gate - 4] Making 'CocinaOpen' a Controller
Thu 03/08/2012 09:45:33 PM : [19 21 CE 3 ] Link 9 : 0FB0 [E203017218FF1F03] Saving [E203017218FF1F03]
Thu 03/08/2012 09:45:33 PM : [1 72 18 4 ] Link 1 : 0FF0 [A2031921CE000003] Saving [A2031921CE000003]
Thu 03/08/2012 09:45:33 PM : [Gate - 4] Finish : Adding to scene 'Open Gate' was Successful
Thu 03/08/2012 09:45:33 PM : [All ] Writing 25 bytes to devices
Thu 03/08/2012 09:45:33 PM : [1 72 18 1 ] Using engine version i1 for 'Gate'
Thu 03/08/2012 09:45:33 PM : [1 72 18 1 ] Link 2 : 0FE8 [0000000000000000] Writing [00..............]
Thu 03/08/2012 09:45:33 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:33 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:33 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:33 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:33 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B E8 06 PEEK (E8)
Thu 03/08/2012 09:45:34 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:34 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:34 PM : [1 72 18 1 ] Link 3 : 0FE0 : Writing High Water Byte
Thu 03/08/2012 09:45:34 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:34 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:34 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:34 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B E0 06 PEEK (E0)
Thu 03/08/2012 09:45:35 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:35 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:35 PM : [1 72 18 1 ] Using engine version i1 for 'Gate'
Thu 03/08/2012 09:45:35 PM : [1 72 18 1 ] Link 0 : 0FF8 [A2151982E7000003] Writing [A2151982E7000003]
Thu 03/08/2012 09:45:35 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:35 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:35 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:35 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F8 06 PEEK (F8)
Thu 03/08/2012 09:45:36 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:36 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:36 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 A2 06 POKE (A2)
Thu 03/08/2012 09:45:36 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 A2 POKE (A2)
Thu 03/08/2012 09:45:36 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:36 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F9 06 PEEK (F9)
Thu 03/08/2012 09:45:36 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 15 PEEK (15)
Thu 03/08/2012 09:45:37 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:37 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:37 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:37 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FA 06 PEEK (FA)
Thu 03/08/2012 09:45:37 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 19 PEEK (19)
Thu 03/08/2012 09:45:37 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:38 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:38 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:38 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:38 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FB 06 PEEK (FB)
Thu 03/08/2012 09:45:38 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 82 PEEK (82)
Thu 03/08/2012 09:45:38 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:39 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:39 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:39 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:39 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FC 06 PEEK (FC)
Thu 03/08/2012 09:45:39 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B E7 PEEK (E7)
Thu 03/08/2012 09:45:39 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:40 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:40 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:40 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:40 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FD 06 PEEK (FD)
Thu 03/08/2012 09:45:40 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:40 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:41 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:41 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:41 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:41 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FE 06 PEEK (FE)
Thu 03/08/2012 09:45:41 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:41 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:42 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:42 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:42 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:42 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF)
Thu 03/08/2012 09:45:42 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:43 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 03 06 POKE (03)
Thu 03/08/2012 09:45:43 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 03 POKE (03)
Thu 03/08/2012 09:45:43 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:43 PM : [MNG-LNK-RSP ] 02 6F 40 E2 15 01 72 18 07 08 00 06
Thu 03/08/2012 09:45:43 PM : [PLM ] Group 21 : Writing Controller Link matching [1 72 18 1 ] Link 0 : 0FF8 [A2151982E7000003]
Thu 03/08/2012 09:45:43 PM : [1 72 18 1 ] Using engine version i1 for 'Gate'
Thu 03/08/2012 09:45:43 PM : [1 72 18 1 ] Link 1 : 0FF0 [A2031921CE000003] Writing [A2031921CE000003]
Thu 03/08/2012 09:45:43 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:44 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:44 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:44 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:44 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F0 06 PEEK (F0)
Thu 03/08/2012 09:45:44 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:45 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 A2 06 POKE (A2)
Thu 03/08/2012 09:45:45 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 A2 POKE (A2)
Thu 03/08/2012 09:45:45 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:45 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:45 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F1 06 PEEK (F1)
Thu 03/08/2012 09:45:45 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03)
Thu 03/08/2012 09:45:46 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:46 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:46 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:46 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F2 06 PEEK (F2)
Thu 03/08/2012 09:45:46 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 19 PEEK (19)
Thu 03/08/2012 09:45:46 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:47 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:47 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:47 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:47 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F3 06 PEEK (F3)
Thu 03/08/2012 09:45:47 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 21 PEEK (21)
Thu 03/08/2012 09:45:47 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:48 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:48 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:48 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:48 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F4 06 PEEK (F4)
Thu 03/08/2012 09:45:48 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B CE PEEK (CE)
Thu 03/08/2012 09:45:48 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:49 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:49 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:49 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:49 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F5 06 PEEK (F5)
Thu 03/08/2012 09:45:49 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:49 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:50 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:50 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:50 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F6 06 PEEK (F6)
Thu 03/08/2012 09:45:50 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:50 PM : [1 72 18 1 ] EZxx start address at 3FFF
Thu 03/08/2012 09:45:50 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F)
Thu 03/08/2012 09:45:51 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F)
Thu 03/08/2012 09:45:51 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:51 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F7 06 PEEK (F7)
Thu 03/08/2012 09:45:51 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:51 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 03 06 POKE (03)
Thu 03/08/2012 09:45:52 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 03 POKE (03)
Thu 03/08/2012 09:45:52 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:52 PM : [iNST-ACK ] 02 62 01.72.18 0F 4F 01 06 IOCTL (01)
Thu 03/08/2012 09:45:52 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 4F 01 IOCTL (01)
Thu 03/08/2012 09:45:52 PM : [1 72 18 1 ] Memory : EPROM Refreshed
Thu 03/08/2012 09:45:52 PM : [19 21 CE 1 ] Using engine version i1 for 'Cocina'
Thu 03/08/2012 09:45:52 PM : [19 21 CE 1 ] Link 10 : 0FA8 [0000000000000000] Writing [00..............]
Thu 03/08/2012 09:45:52 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:45:53 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:45:53 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:53 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B A8 06 PEEK (A8)
Thu 03/08/2012 09:45:54 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:54 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:54 PM : [19 21 CE 1 ] Link 11 : 0FA0 : Writing High Water Byte
Thu 03/08/2012 09:45:54 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:45:55 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:45:55 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:55 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B A0 06 PEEK (A0)
Thu 03/08/2012 09:45:56 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 00 PEEK (00)
Thu 03/08/2012 09:45:56 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:56 PM : [19 21 CE 1 ] Using engine version i1 for 'Cocina'
Thu 03/08/2012 09:45:56 PM : [19 21 CE 1 ] Link 9 : 0FB0 [E203017218FF1F03] Writing [E203017218FF1F03]
Thu 03/08/2012 09:45:56 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:45:56 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:45:56 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B0 06 PEEK (B0)
Thu 03/08/2012 09:45:57 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B E2 PEEK (E2)
Thu 03/08/2012 09:45:57 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:57 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:45:57 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:45:57 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B1 06 PEEK (B1)
Thu 03/08/2012 09:45:58 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 06 PEEK (06)
Thu 03/08/2012 09:45:58 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:58 PM : [iNST-ACK ] 02 62 19.21.CE 0F 29 03 06 POKE (03)
Thu 03/08/2012 09:45:58 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 29 03 POKE (03)
Thu 03/08/2012 09:45:58 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B2 06 PEEK (B2)
Thu 03/08/2012 09:45:59 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 01 PEEK (01)
Thu 03/08/2012 09:45:59 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:45:59 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:45:59 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:45:59 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B3 06 PEEK (B3)
Thu 03/08/2012 09:46:00 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 72 PEEK (72)
Thu 03/08/2012 09:46:00 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:46:00 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:46:01 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:46:01 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:46:01 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B4 06 PEEK (B4)
Thu 03/08/2012 09:46:02 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 18 PEEK (18)
Thu 03/08/2012 09:46:02 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:46:02 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F)
Thu 03/08/2012 09:46:03 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F)
Thu 03/08/2012 09:46:03 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:46:03 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B5 06 PEEK (B5)
Thu 03/08/2012 09:46:04 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 05 PEEK (05)
Thu 03/08/2012 09:46:04 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:46:04 PM : [iNST-ACK ] 02 62 19.21.CE 0F 29 FF 06 POKE (FF)
Thu 03/08/2012 09:46:04 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 29 FF POKE (FF)
Thu 03/08/2012 09:46:04 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B6 06 PEEK (B6)
Thu 03/08/2012 09:46:05 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 1C PEEK (1C)
Thu 03/08/2012 09:46:05 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:46:05 PM : [iNST-ACK ] 02 62 19.21.CE 0F 29 1F 06 POKE (1F)
Thu 03/08/2012 09:46:05 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 29 1F POKE (1F)
Thu 03/08/2012 09:46:05 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B7 06 PEEK (B7)
Thu 03/08/2012 09:46:06 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 06 PEEK (06)
Thu 03/08/2012 09:46:06 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:46:06 PM : [iNST-ACK ] 02 62 19.21.CE 0F 29 03 06 POKE (03)
Thu 03/08/2012 09:46:07 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 29 03 POKE (03)
Thu 03/08/2012 09:46:07 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 03/08/2012 09:50:12 PM : [iNST-ACK ] 02 62 00.00.15 CF 11 00 06 LTONRR (00)
Thu 03/08/2012 09:50:12 PM : [ 19 21 CE 3] ST 255
Thu 03/08/2012 09:50:12 PM : [ 1 72 18 4] ST 255
When I add the link manually, the shn utility shows thet link when set in the small database, it didn't show if I select the large database.
The links that ISY creates shows only when I select the large database.
I have to conclude this is not a new EZIO4O. The internal PLM has a large memory configuration which is correctly detected by the ISY and that is where the ISY is writing link records. The internal PLM is writing Set button link records as though it is a small memory configuration. This device cannot be used with ISY Scenes.
EDIT: I also noticed the internal PLM does not support the extended ALDB command used for link management. This is an additional indication the PLM is not new. Both of my new EZIOxx devices from SHN support the extended ALDB command.
Thanks for your help...
I will contact smarthome for a replacement, I just purchase this unit 3 weeks ago...
fuentesa
I've had a discussion with Simplehomenet regarding the EZIO4O test results. Likely related to the EZIO4O PLM that is currently being used. The PLM is new (did not mean to imply the EZIO4O was a used device) but it looks like the PLM does not recognize the large memory configuration nor does it handle the extended ALDB command.
As a work around you can use an ISY Program that triggers on the device that initiates the Open Gate Scene and have the ISY Program send a Direct command to the desired EZIO4O Relay.
I was thinking of something similar. I don't know if it will introduce some lag to the response though.
Is there an option for you to manually select the type of EZIO40? Small or Large? Probably for a future version?
There is no option to manually specify the location of the link database. I suspect the errors that type of option could generate would override the limited usefulness. There are at least four different starting points I am aware of today. That type of option would be chasing a moving target.
There will be a small delay driving the relay from a Program. I turn on the bathroom lights with a Program triggered from a motion sensor. The delay is very small.
