Time Flags
C Martin
Just FYI.
For all of you and this should be a lot of people, I use time programs as flags for different types of times that I use for program control. I.E. Sunset, Sunrise, Night time, Good Night,an other misc time periods that I use. With some of these time periods, I use Random Waits commands to simulate security times.
This eliminates the re-using of Sunset or sunrise codes multiple times or other time setups that are used frequently.
Example:
From Sunrise
To Sunset (same day)
I use these with Folders that are enabled by these flags and programs that will fire when these folders are enabled.
Folder Conditions for 'Goodnite Lighting Folder'
Program 'GoodNite Flag Pgm' is True
Folder 'Goodnite Lighting Folder' is True
Wait 15 minutes (Random)
Run Program 'Goodnite Lighting Pgm' (Then Path)
This can be utilized when you need to interrupt a program and re-establish the program again.
I posted this because I noticed a posting about using timed programs recently.
I hope that is information is of some use and help to others in this forum.
I also hope that I explained this clearly. If not I can answer and give some more examples.
Some other examples of my time flags:
Evening Flag:
From Sunset
To Sunrise (next day)
Goodnite flag:
From 11:00:00PM
Run Program 'Sunset Flag Pgm' (Else Path)
Example of a prgram that uses a flag program:
Program 'Evening Flag Pgm' is True
And Control 'KeyPad Switches / KeyPad Side Yard Light ©' is switched On
Set 'Exterior Lights / Side Yard' Fade Up
Wait 15 minutes
Set 'Exterior Lights / Side Yard' Fade Down
Set Scene 'KeyPad Switches / Key Pad Toggles / KP Side Yard On/Off Toggle' Off
Set 'Exterior Lights / Side Yard' Off
Good information C Martin, without variables, flags are our only option. I follow similar logic and established time flags for all sorts of things:
Flag Away
Flag Awake
Flag Dark
Flag Garage
Flag Leaving
Flag Outdoors
Flag Party
Flag Prime
Flag Rain
Flag Vacation
Flag Watering
Name convention beginning with 'Flag' allows me to sort/find them when troubleshooting. None of my ‘flag’ programs have conditions or then/else actions. They merely track TRUE or FALSE condition. Like C Martin, I use these flags as conditions on a number of folders and/or other programs I have.
Other programs are necessary to control their condition. Here is one example:
Program PrimeTime:
. From Sunset - 45 minutes
. To 11:30:00PM (same day)
. Run Program 'Flag Prime' (Then Path)
. Run Program 'Flag Prime' (Else Path)
Sets prime time flag:
- Then path is true between 45 minutes before Sunset and 11:30 PM.
- Else path is false for all other times.
Following C Martin’s form, I could combine this condition in Flag Prime program, eliminating the need for this example. However, some flags have multiple triggers and/or conditions. I guess I just need to keep things simple.
Hi C Martin,
I see one issue. Start Fade Up/Down with no end (Fade Stop) will never update the ISY state of the device.
I suggest you create a scene with the On Level/Ramp Rate you desire And then call that scene On or Off. Then the ISY can interpolate the states of the devices in the scene.
Rand
      379.8k
