Recently installed Weatherbug, question!
I just installed the weatherbug module a few days ago. I have a question, because things just don't seem right.
I've used my zip code as my location ID, and I've even used the Locate Me feature. The problem is that the conditions displayed are not my local conditions. Right now it's telling me it's -7F outside, when it's actually about 65F.
Did I miss something here? Is there documentation somewhere that explains how to use this feature and set it up properly?
I had not seen the wiki, thank you.
Seems the problem is that the list of stations is not coming up when I enter my location and choose my area.
Something seems wonky.
Got it. It took about 30 seconds for the station list to come up. I guess I just wasn't waiting long enough, although I wouldn't have expected it to take that long. :D
I don't know all the ways it works.
I almost think it goes out and checks what is avilable in you area after you input a location. I believe it also gives you a list of exactly what each station supports. As some have added data other do not.
