What am I doing wrong??
I am sure this is really really simple but when I use this program, the light never turns off.
If: From sunset to sunrise
and control motion sensor is turned on
and status front door light is off
Then:
sert front door light on
wait 3 min
set front door light off
Thank you for your time!!
The Wait causes the If to be reevaluated. The "and status front door light is off" is no longer True so the remainder of the Then does not run. The standard solution for this type of problem, where the Program changes the If conditions and has a Wait or Repeat is to break it into two Programs. Program1 has the If and Run Then Program2. Program2 has the current Then statements.
