program summary True or False
Hello all:
I'm looking for an explanation as to what "True" or "False" (in the Status column of the program summary) means to the ISY.
"Activity" (Idle, Running Then, Running Else) is self explanatory. But I don't really grasp True or False in this context.
Anyone care to take a stab at explaining this?
If we get a good definition, we can update the Wiki.
Thanks much
From what I understand its...
The 'Status column' displays the status of the If statment for each porgram at that moment in time.
...a small stab, I am sure its not the best answer.
A program always has a state of either True or False. This state can be used as a condition in a program (ie. if 'Program X' is True then ...).
A program becomes True only when its 'Then' path is run.
A program becomes False only when its 'Else' path is run.
Nothing else changes the True/False state of a program.
When a program is run (either Then or Else) then it is an event for any program referencing it, thus causing the program referencing it to run (either Then or Else depending on that programs conditions).
By having a True/False state, you can have a complex set of conditions for one program, and reference it from another program.
For example, you may want to have programs that only do things during, (or some not during) office hours.
eg.
Program Office Hours:
       On Mon, Tue, Wed, Thu, Fri
       From     9:00:00AM
       To       5:30:00PM (same day)
    Or On Sat, Sun
       From    10:00:00AM
       To       2:00:00PM (same day)
Turn the lobby lights on during office hours (off otherwise):
       Program 'Office Hours' is True
       Set 'Lobby ' On
       Set 'Lobby' Off
keep the conference room light off outside office hours, and only allow the conference room switch to work during office hours:
   And Control 'Conference Room' is switched On
       Set 'Conference Lights' On
       Set 'Conference Lights' Off
