Problem with 3.02
After update, when tapping on a program in the favorites list, it doesn't perform the specified action as before, rather it opens the program screen where you are given the choice of running the if/then/else, etc. The same as if you went to the programs page and tapped the program name.
I would suggest upgrading to 3.1.5 or .6 if you are ok with the backup bug and see if the problem persists.
Hi Ryarber,
This was done on purpose. To activate the favorite action on your program under My Favorites, tap the Gear Icon. If you want to tunnel into the program, tap the program cell (just how you described). This brings the program interaction in alignment with the Scenes and Devices where the icon drives the command and tapping on the cell body dives into the details.
Wes
