rm1505 Posted September 8, 2011 Posted September 8, 2011 I just got a new ISY-99i with the X-10 software add-on. After completion of the first programs I tried to do a backup and got these error messages: Could Not Create Zip File Could Not Retrieve File/CONF/UDFLPL.XLM How can I correct that situation?
oberkc Posted September 8, 2011 Posted September 8, 2011 Which firmware version of the ISY are you running? I think I saw that one of the latest versions had a known bug which precluded backup operations.
rm1505 Posted September 8, 2011 Author Posted September 8, 2011 Thanks for the fast response. Where can I find the firmware revision? Here is my serial number: 015899
oberkc Posted September 8, 2011 Posted September 8, 2011 From memory (not certain). At the admin panel, check under help, about, (or similar). You should see version something like 3.1.6, or 2.8.16, or something like that.
LeeG Posted September 8, 2011 Posted September 8, 2011 I think the answer can be found in this post … viewtopic.php?f=25&t=6279&p=49452&hilit=UDFLPL#p49452 The suggestion is to open the Floor Plan and Save or telnet into the ISY and issue the command shown in one of the posts. Suggest reading through the entire topic. A few unrelated posts but most related to your symptom.
rm1505 Posted September 8, 2011 Author Posted September 8, 2011 Thank you very much! I opened and saved the floorplan. I works now.
