Simple timed program not working in 3.1.9?
I have a program called TS (Home)
       On Mon, Tue, Wed, Thu, Fri
       Time is  3:30:00PM
       Set Scene 'SCENES / THERMOSTAT / TS (Home)' On
       Run Program 'TS (Chk4Fan82)' (If)
Monday thru Friday at 3:30pm
1. Set Thermostat Setpoints for comfort (Turns on HW (KP-A))
Here's the program it calls:
       Status  'DEVICES / THERMOSTAT / TS (Thermostat)' >= 82° (Temperature)
       Set 'DEVICES / SWITCHES / LR (Ceiling Fan)' On
Called from TS (Home)
and here's my program summary
Shouldn't this be scheduled for tomorrow at 3:30pm? Anything to do with the program it runs not being enabled?
EDIT: Now it shows correctly, but it also shows it didn't run until 3:39pm instead of 3:30pm.
The program has to run once to get the next run time I believe. When you write a new program that is time based you might want to run it and let it else out.
Hi andyf0,
Just curious if you found the cause yet and whether the programs are running as expected?
Tim
