ISY Time zone
Hello, having some trouble with the time in the ISY. I live in Champaign, Illinois, which is in the Central time zone so I use Chicago because it's the most logical (though as a side note I find it interesting a very small town in my County, Bondville, IL is listed but Champaign isn't?), anyway, the time is always one hour slow. I had to select New York (in the Eastern time zone) to get the ISY set to the correct time. I have not had this issue before and only noticed it since upgrading to 3.1.10 beta earlier today trying to fix a linking issue. Anyone else seen this problem?
I'm running:
ISY 99i Pro (1040)
Running ISY99i V.3.1.10
PLM: v92
Thank you in advance!
Greg
Try using a different time server (us.pool.ntp.org) Also try a city not so close the time zoneline.
Not sure if the ISY DST determination is look up table or is formula based, but I have seen formula based implementation get it completely wrong, or change a week prior or late. If the time is correct after this Sunday, we will know it is formula based or the offset is wrong for your city.
