Quick programming question
ixlr8
I am running 2.8.16 on an XP machine. I want to turn off a light in the house when the garage door sensor goes to OPEN. I can't figure out how to do this. It would be simple if I could put a CONDITION in the THEN statement, but it looks like I can't do that. Am I missing something obvious? Any suggestions would be appreciated.
TIA- Jim
I would do this via program:
if
control "garage door sensor" is set on
then
turn "light in the house" off
else
Actual code wording may vary, but I trust the logic is clear.
A little more detail on what I am trying to do. Here is my present code, on select days of the week turn a light on at 5:40am. Instead of turning the light off after 30 minutes, I want to turn it off when the garage door sensor indicates the door has been opened. What you see is about the limit of my very basic code writing ability.
       On Mon, Wed, Thu
       Time is  5:40:00AM
       Set 'LR Table Lamp' On
       Wait  30 minutes
       Set 'LR Table Lamp' Off
Is the "little more detail" the same as "all the rest of the detail"?
Perhaps it best to describe, in english (as opposed to a program example) what you want to accomplish. For example:
a. table lamp to come on at 0540 on mondays, wednesdays, and fridays.
b. table lamp to remain on until garage door is open, or 2 hours after sunset, whichever comes first.
Is this it? Assuming so, change your first program to:
       On Mon, Wed, Thu
       Time is  5:40:00AM
Create a second program...as I suggested earlier, modified:
       control garage door sensor is set on
or
       time is sunrise + 2 hours
Here is anoter take on it.
You need a global state variable "WakeupState" with an initial value of 0. Modify your first program as below:
       On Mon, Wed, Thu
       Time is  5:40:00AM
       $WakeupState = 1
       Wait  30 minutes
       $WakeupState = 0
Now, add a second program:
       Control 'Garage Door Sensor' is switched on
And     $WakeupState is not 0
       $WakeupState = 0
Good luck!
Thank you for the ideas, I appreciate it. I was hoping to be able to do it in one program, I am going to experiment with all suggestions.
Thanks again.
You'll need to upgrade to v3 of the firmware to experiment with variables. Alternatively in v2 you can use programs as (binary) variables (true or false)
Sent from my iPod touch using Tapatalk
Oops, sorry. Didn't see the 2.8.16 in the first post. Just change every "$WakeupState = 1" to "Run Program 'WakeupState' (Then Path)," "$WakeupState = 0" to "Program Program 'WakeupState' (Else Path)," and "$WakeupState is not 0" to "Program 'WakeupState' is not False."
Well, I tried to do the programming the way that oberkc suggested, it worked but it was cumbersome keeping everything straight and not conflicting other programs controlling that light. So... I downloaded beta version 3.1.10 and set up a variable. Much simpler and no issues with conflicting with other programs on that light.
Thank you all for your help.
      37.6k
      376.2k
