Error trying to add a new INSTEON device - [-200000/-9]
When i was going through the bulk add process by pressing the SET button to discover the devices and add them, I had one SwitchLinc that couldnt be found.
When I try and add that individual device (address 04.1B.85) I keep getting this error:
"Failed writing device link
(Master Bedroom Closet)
[-200000/-51]
Node not added - failed removing links
(4 1B 85 1)
[-200000/-9]
I don't know why there is some dependency on updating the info for the Master Bedroom Closet SwitchLinc.
What do those errors mean?
Rick
The ISY does not have reliable communication with that SwitchLinc.
Apologies, most of the post was not pasted.
Depending the option used for resolving existing links, "erase existing links", etc the ISY will clear current links or not but will write additional links to connect the new device to the ISY PLM. There is a fair amount of command activity involved so issues with powerline reliability on a particular circuit will often surface during the device add and/or Scene creation.
