AT&T to end email-to-text ×
Utility to show which programs utilize certain devices
pdxcav
As my ISY program library grows (a good thing!), I find increasingly that I have some old program still enabled (that I forgot to disable) that will cause weird behavior. An example: an old program that responds to a KeyPad Button push that I completely forgot I had and then later I use that button for another purpose.
As far as I can tell, the only way to find this is to manually look at every program which is tedious & for me in particular, error prone.
It would be great if the ISY had a utility that would allow me to select a particular device and then search through the program library to report where it is used.
Perhaps even better, it would be great to see this info in the is responder to/is controller for section of the lighting devices.
Under Programs | Summary right click and select Find/Replace. The Find will highlight all the Programs with a particular device reference. This also works under the Details tab.
      37.7k
      376.5k
