RemoteLinc v.35 (2440)
I have a question about the behavior of a RemoteLinc. I want the 5 of the 6 buttons to control scenes. The scenes will manage the % brightness of two tracks of lights running on two SwtichLincs (v.38 item 2476D). I created 5 scenes. For brevity I'll talk about the "Scene A" and "Scene B" buttons.
They should work as follows:
1. When the "Scene A" both tracks should turn on at 100%.
2. When the "Scene B" one track should turn on at 30% and the other at 50%.
When I'm testing them, I'll use the "Scene B" button a couple times and then the "Scene A" button a couple times, they work properly. However sometimes the "Scene B" button will turn the tracks on to the 30%/50% and then very quickly set the "Scene A" button to "on" which seems to then turn the tracks on to 100%.
Just so you know, I had factory reset the SwitchLincs and RemoteLinc prior to adding them to my ISY99i. I put the log at this link: http://screencast.com/t/8IXeK0iA. Any ideas?
Steve
SteveSBE
The RemoteLinc buttons cannot be turned On Programmatically. The RemoteLinc has no Responder capability and is likely asleep (although maybe not asleep in this scenario).
Suggest running Tools | Diagnostics | Event Viewer with Device communications events selected. Post the event log when Scene A turns On unexpectedly. I suspect there is a Scene A On coming from the RemoteLinc.
Lee
