Enabling a Folder
I am creating a Power On Reset Schema.
I have programs that I want to run when the ISY Reboots.
I have a folder called Power on Startup.
The idea is - those programs only run during an ISY power-up.
Folder Conditions for 'Power on Startup'
Add conditions to limit when programs in this folder are allowed to run.
       Program 'Power On Startup Pgm' is True
My program that runs on Power up is:
       From    Sunrise
       To      Sunrise (next day)
       Wait  2 minutes
       Run program 'Power On Startup Pgm' (Else Path)
I tried running the Program with no conditions but it didn't work - that's why the from Sunrise - to - Sunrise (next day) is in the if statement.
I would have thought that just running the program as a "Status" "True" would trigger the Folder to be enabled - but no dice.
Just for completion, here is my folder contents:
       From    Sunrise
       To      Sunset  (same day)
       Set Scene 'Sunrise Scene' On
       Run program 'Check PM Time Status Pgm'
AND
       From    Sunset
       To      11:00:00PM (same day)
       Wait  1 minute
       Set Scene 'Sunset Scene' On
       Set Scene 'Good Nite Scene' On
Triggering the folder and the programs in contains seems like it could be a little tricky. Could you just put your initialization code in a single program and set it to "Run at Reboot" in the program summary screen?
