OK, next problem (setup ISY99) - wont recognize remotelinc
Hi,
So now I've got all my hard wired devices controllable from the isy99. But the direction for finding the remotelinc dont seem to work. I put the remotelinc in linking mode, but in the window then next thing that comes up is a window stating "new insteon device" - there's nothing about this in the directions - how do I figure out the name and address?
Second issue:
control and response from my Venstar t1800 seem a little spartan. I would have thought I could read the temperature, reprogram the settings, etc. Its found it but basically just reads "heat on" or "cold off"
Any advice welcome - thanks!
For the RemoteLinc the Name is your choice The Insteon Address is found in the battery box along the bottom edge. Remove the bottom battery to see label.
