Force Firmware Update? (t-stat problems)
I got my ISY99i in this week, and got it all set up and programmed yesterday. I noticed that the firmware is 2.8.16. Registered it this afternoon on UD's website...
(I searched the forum, apparently 'firmware' is too common, so the software won't let you search for it!)
How do I get this sucker to update the firmware?
The ISY99i only will automatically update if a new Official Firmware release is done.
You have to manually update for Beta Releases.
viewtopic.php?f=25&t=7575
Make sure you follow the directions carefully.
Like clearing the Java temporary files
Meh, I did the manual upgrade to 3.1.14...
One of my LampLincs is fubar, I think. It was acting flaky before I got the ISY99i in... I've ordered a few X10 lamp modules to replace that one and add on a couple more lamps.
The problem I'm having now is one of my thermostats. Either from Conductor (on my Android phone) or through the Admin Console, if I set the heat setpoint, it refreshes in the console, but doesn't change on the thermostat. Query the thermostat, and it shows the previous setting.
The Setpoint Up 1 and Setpoint Down buttons on the Admin Console actually DO work. The HTML page controls work under Devices as well. It's just the setting through the Admin Console, and on Conductor. Changes via programs appear to work fine, too.
My downstairs thermostat (same stat, same dongle, v1.3) works fine when doing any of the above.
I just deleted the device and re-linked it. No change. I'm gonna do a little digging around in the forums to see if I can find anything that may help.
Now I'm poking around.... and it's working. All I did was add it back to the scenes that it dropped out of when I deleted and re-added the device.
Perhaps something was messing with communications? I don't have anything else that would be transmitting on the same band in the house. (no baby monitors or anything)
The dishwasher may have still been running, but that's downstairs. Oddness. I'm going to have to keep an eye on it.
