Add actions to folders
Zellarman
I'm trying to figure out a way to address specific controllers and or groups w/ ir comands. ie; programming universal ON OFF DIM & BRIGHTEN comands that would be preceeded by a specific ir command to address the desired group. I'm thinkng if I could create folders for each specific device that would time out, then I would be able to accomplish this.
for example
IF ir '1' is pressed
allow programs in this folder to run
WAIT 10 seconds
don't alllow programs in this folder to run
does this make sense to anybody?
  • 3 weeks later...
I read your post and thought of an easy way to do this. Create a program like the following:
Program Content for 'test'
       Control 'Remote-button 1' is switched On
       Wait  10 seconds
       Run program 'test' (Else Path)
Then add a condition to your folder for "Program 'test' is True. This enables all of the programs in the folder for 10 seconds. I used a RemoteLinc to test it, but I would think it will work the same with IR.
