Mobilinc with Android Phone????
Is any one using Mobilinc on an android phone. I purchase it and everything was running fine. Then it stopped connecting via 3g. I have the correct HTTP and HTTPS addresses! and the IP address has not changed. It just stopped connecting. I can however still connect via wi fi.
There's a subforum for the software in the forum list.
I tried it on my phone, but I like Conductor a bit better. Do wish they would get the tablet version out soon, tho.
I am having the same issue, it says that it connect to my light controller. It seems to be just mobilinc I'm having the issue with, I am able to toggle
things back and forth with other apps such as Conductor and the Admin Console of the ISY.
Hi All,
Problem seems to be solved, I unplugged the ISY for about 1min and then plugged it in again. Mobilinc Pro connected right away on 3g and also wi fi. Has been working just as it is supposed to.
