David D Posted December 29, 2011 Share Posted December 29, 2011 I have two older KPL's (2486D v.26) on the nightstands in our master bedroom that control the bedroom lights as well as activate a "wake up" and "bedtime" scene/program via the "A" button. In the morning, the "A" button is supposed to toggle on to turn on the lights in the living room and kitchen. At bedtime, the "A" button gets toggled off to turn off all the lights in the house, except for a lamp in the dining room and our post light which both get dimmed. Problem is, the "A" button light (status) on both KPL's is very unreliable. Most of the time, I will toggle the button off (bedtime) and all the lights will shut off, but the button will remain lit. I have recently installed a dual band lamp module for the lamps on the same nightstands as well as a couple more to help things, but no joy. Any ideas? I'm using these programs to control the KPL button lights: (Nighttime lights status) If Status 'Living Room Lamps' is not Off Or Status 'Kitchen Lamp' is not Off Or Status 'Dining Rm Lamp' is not Off Then - No Actions - (To add one, press 'Action') Else - No Actions - (To add one, press 'Action') (MBR KP (D) Button A Status) If Program 'Nighttime Lights Status' is True Then Set Scene 'MBR KP (D) Button A Status' On Set Scene 'MBR KP (A) Button A Status' On Else Set Scene 'MBR KP (D) Button A Status' Off Set Scene 'MBR KP (A) Button A Status' Off For reference, MBR KP (D) is mine (David), and MBR KP (A) is my wife's (April). They're both supposed to function the same. Is there a better (more reliable) way to do this? Link to comment Share on other sites More sharing options...
TJF1960 Posted December 29, 2011 Share Posted December 29, 2011 Hi David, I am not sure at this point if it is a comm. issue with the KPL's or a program issue. You might try adding a Wait 1 or 2 seconds before the action of the Then and Else in the program to give any Insteon traffic from any of the lights included in the first program time to finish before the ISY issues the On or Off commands. (MBR KP (D) Button A Status) If Program 'Nighttime Lights Status' is True Then Wait 2 seconds Set Scene 'MBR KP (D) Button A Status' On Set Scene 'MBR KP (A) Button A Status' On Else Wait 2 seconds Set Scene 'MBR KP (D) Button A Status' Off Set Scene 'MBR KP (A) Button A Status' Off Tim Link to comment Share on other sites More sharing options...
oberkc Posted December 29, 2011 Share Posted December 29, 2011 Most of the time, I will toggle the button off (bedtime) and all the lights will shut off, but the button will remain lit. So button A is, initially, on. You press button A. It stays on!? (Is it in toggle mode?) This does not suggest communication problems, but either a hardware problem, or, as TJF1960 suggests, your programs are turning it back on. I like the addition of the wait statement, but suspect there is something else going on, as well. Is the button A a controller of a scene? With what other devices? What are the other programs triggered by button A (I assume you have bedtime and wakeup program)? Is it possible that button A is controller of a scene with 'Living Room Lamps' as responder? Is it possible that your bedtime program, triggered by button A off command, tells 'Living Room Lamps' to turn on to "dimmed" setting? If so, you may have a chain of events going on: At the end of the day, you press button A (goes from on to off). Because of the scene, a bunch of lights turn off, and 'nightime ligts' status goes false. A few milliseconds later, your bedtime program fires, turning 'Living Room Lamps' to your dimmed setting. This causes 'nightime lights status' to turn back to true. This causes 'MBR KP (D) Button A Status' to trigger (now true) turning button A back on. Does this scenrio sound plausible? Link to comment Share on other sites More sharing options...
David D Posted December 29, 2011 Author Share Posted December 29, 2011 Maybe this will help. Here's my "bedtime" and "wake up" programs: (Bedtime) If Control 'Master BR KP (D) - Button A' is switched Off Or Control 'Master BR KP (A) - Button A' is switched Off Then Set 'Living Room Keypad - Post Lig' 50% Set 'Living Room Lamps' Off Set 'Kitchen Lamp' Off Set 'Dining Rm Lamp' 35% Set 'Den Wall Switch' Off Set 'Den File Cabinet' Off Set 'Den Desk' Off Else - No Actions - (To add one, press 'Action') (wake up) If Control 'Master BR KP (D) - Button A' is switched On Or Control 'Master BR KP (A) - Button A' is switched On Then Set 'Living Room Lamps' On Set 'Dining Rm Lamp' On Set 'Kitchen Lamp' On Else - No Actions - (To add one, press 'Action') Link to comment Share on other sites More sharing options...
David D Posted December 29, 2011 Author Share Posted December 29, 2011 Hi David, I am not sure at this point if it is a comm. issue with the KPL's or a program issue. You might try adding a Wait 1 or 2 seconds before the action of the Then and Else in the program to give any Insteon traffic from any of the lights included in the first program time to finish before the ISY issues the On or Off commands. (MBR KP (D) Button A Status) If Program 'Nighttime Lights Status' is True Then Wait 2 seconds Set Scene 'MBR KP (D) Button A Status' On Set Scene 'MBR KP (A) Button A Status' On Else Wait 2 seconds Set Scene 'MBR KP (D) Button A Status' Off Set Scene 'MBR KP (A) Button A Status' Off Tim Thank you Tim. I gave that a try and get the same results. I also tried upping the "wait" time to 6 seconds that didn't help either. Is there anything else I should look at programming-wise? Link to comment Share on other sites More sharing options...
oberkc Posted December 29, 2011 Share Posted December 29, 2011 Your bedtime program sets 'Dining Rm Lamp' 35%. This change, alone, will trigger program "Nighttime lights status". Since dining rm lamp is not off (now at 35%), the program will evaluate as "true", which will trigger program 'MBR KP (D) Button A Status', which will turn 'MBR KP (D) Button A Status' and 'MBR KP (A) Button A Status' on. I consider this to be the most likely cause of your problem. I am still curious if your keypad buttons are also scene controllers. This may still be a factor that neads dealt with. May I assume that your failure to mention this means that they are not? My quick suggestion to confirm this theory is to remove your dining rm lamp from your program 'Nighttime lights status' to see if this solves your problem: If Status 'Living Room Lamps' is not Off Or Status 'Kitchen Lamp' is not Off Or Status 'Dining Rm Lamp' is not Off << Then - No Actions - (To add one, press 'Action') Else - No Actions - (To add one, press 'Action') Link to comment Share on other sites More sharing options...
David D Posted December 29, 2011 Author Share Posted December 29, 2011 Ok, it took combining both suggestions and it seems to be working reliably now! I deleted the dining room lamp per Oberkc's suggestion and added the 2 second delay to the status programming. Thanks! Link to comment Share on other sites More sharing options...
